 Curtain rail track installation
BLEE
Initially Posted - 01/01/2007 :  19:14:49  Show Profile
I am installing curtain rail tracks as my 85 does not currently have any and the admiral would like a privacy option. I am considering using #6 1/2" screws and attaching the tracks directly to the fiberglass above and below the cabin windows. I know the cockpit bulkhead is 1" thick and am assuming the cabin wall thickness around the windows are at least 3/4" thick. Does anyone know if this is a good assumption (don't want screw holes to go all the way through the cabin walls). Has anyone installed curtains recently that can share their experience?
Bob Lee
Knotty Dream
Knotty Dream
mashedcat
Response Posted - 01/02/2007 :  13:13:55  Show Profile
catalina direct
http://www.catalinadirect.com/index.cfm?fuseaction=product.display&Product_ID=39
Response Posted - 01/02/2007 :  19:28:54  Show Profile
'thickness around the windows are at least 3/4" thick'
As I recall from back when I had my windows out... it was quite a bit thinner than that. 3/8 plywood core, couple layers of glass.
mashedcat
Response Posted - 01/02/2007 :  21:17:57  Show Profile
If you buy the clips from cd, you can mount them with pretty short screws. I used 1/2 inch. You only have to get into the fiberglass, and a little of the wood. The wood itself is a little more than 1/2 inch.
Edited by - mashedcat on 01/02/2007 21:20:48
captck
Response Posted - 01/13/2007 :  20:28:22  Show Profile
May consider short 1/8" pop rivets to hold tracks in first layer of glass. Dip in silicone before poping in place.
Happy trails to you.
