 Lifeline re-bed '89 pics
Scooter
Initially Posted - 02/05/2007 :  06:46:59  Show Profile
This is how I ended up accessing the lifeline mount. Used a Dremmel. Could have made a smaller hole.
This is the before.
This is the After.
Note the outboard nuts are between the bulkhead and the overhead of the deck. You can't get a socket on the nut. You have to get to the nut from the side. I will likely have to get one of those new (7/16) open-end wrenches with a knee joint to get to them? Too cold to re-mount them yet. Getting the bolt started should be fun.
Watch the wires when cutting the hole. I used a coat hanger bent in an "L" shape with a little hook on the end. I held the wires up while cutting.
Wish me luck re-bedding. It'll be tight but looks do-able.
Scooter
C25 '89 SR/WK #5878 "Square Knot"
Vandemere NC.
Response Posted - 02/05/2007 :  07:58:47  Show Profile  Visit Frank Hopper's Homepage
You are doing great, a piece of teak, a couple of screws and it will look fine.
Response Posted - 02/05/2007 :  09:31:56  Show Profile  Visit aeckhart's Homepage
Perhaps the "powers that be" should put this in the Tech Tips. The final product would make a good article for the Mainsheet.
Response Posted - 02/05/2007 :  10:19:35  Show Profile  Visit Frank Hopper's Homepage
11 more posts Al then you are a power that be.
bear_tm4
Response Posted - 02/05/2007 :  11:47:02  Show Profile
WOW, I am looking at doing the same job on my boat this spring if it ever gets warm, this thread prompted me to check mine out. I am blessed that all of mine are easily accessible with out a lot of effort. Keep us posted this great learning opportunity. Do you plan on refiling the holes with epoxy and redrilling?
