New halyards arrived last week - these have a small sewn loop or eye at the end designed, I think, for attaching to the old halyard so it can be pulled through the mast without mishap. I'm soliciting advice for how to best fasten old to new so they run freely & won't part inside the mast. Thanks -
That eye is for the shackle at the headboard of the sail. There was a recent discusion on reeving new halyards, and the best suggestion (IMHO) was to butt join the old to the new and sew them, then cover w/ a thin wrap of tape. That's going to be method this weekend.
Hi Jerry -- nope, the eye for the shackle is at the other end, larger & heavier. This eye is for reaving only (so says the attached label). Think I'm going to end up using the stitch & tape method though as it seems least likely to hang up inside the spar.
Remember you can cut up the old halyard, so you can cut the headboard shackle off the old halyard and melt it to get a nice clean butt. If I had a "reeveing loop", (new one on me), I might sew strip of cloth to the old halyard, pass it through the reeveing loop, and sew the other end onto the old halyard as well; loop to loop. You could stagger the locations of the ends of the cloth strip to avoid too much diameter build up on one spot of the old halyard. Probably 6-10 loops of heavy thread would work as well as the strap and be much faster.
Sewing might be the best bet. I replaced mine last year and did NOT do this. I just taped the end together, used a little extra tape and figured "That should hold her".. As soon as the two ends made their way into the pully I quickly had two ends of line laying at my feet..
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by dlucier</i> <br />Can't speak for a C250 masthead, but on my C25, if the reeving loop was larger than the diameter of the line, it wouldn't make it through my masthead. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
You can do what we did which was to tape them together very tightly. Then, when the connection reaches the sheeve at the top of the mast, it gets jammed and you pull harder. Then the connection breaks. Then you lower the mast to get it done.
Sewing sound like the best bet. Keep the connection flexible or it wont go through the sheeve area. There is very little tolerance up there and your connection must be able to make a <b>very </b> tight turn.
Have you spoken w/ your supplier to get their explanation? Failing that, and I hate to say it, but I'd consider chopping off the smaller eye - can't understand how it will fit over/through your mast head....
Thanks all. I did call the rigging shop at West Marine but couldn't reach anyone; finally pulled a foot or so of core out of the old halyard & cut off the same distance of exterior weave, then tied the core tightly to the reeving loop and taped round it. Cake. Tomorrow we haul to new water -- Bayfield, Wisconsin, and the Apostle Islands. Anyone familiar?
Bayfield, WI is a wonderful place to be. The Apostle Islands are very scenic, and Bayfield itself has a charm all its own.
If you are into racing, there is a pretty active racing scene organized by the Apostle Island Station of the Wayzata Yacht Club (schedule online at http://wyc.org/Schedule-AIS.htm). I know there are also other Clubs in Bayfield as well.
Bayfield race week is held during the first week of July. It is a wonderful week long festival of sailing, with a spectacular firework display on the 4th. Sailfest takes place on the Saturday following race week. It is a chance for cruising sailors to try their hand at racing in a low-key, run atmosphere, with assistance from volunteer racers.
