I would like to add chain to our new 14lb Delta anchor as we plan to anchor out in Lake Erie and a possible trip to the North Channel this summer. Our other anchors are 13lb danforths on 125'of 3/8 rode and 4'of vinyl coated chain, I have two questions. Electric galvanized or hot dipped galvanized which is the least likely to rust in freshwater? Is 40' of 1/4" chain what I should add to our 100' of 3/8 rode.I'm after an anchor system that will set well in most bottom conditions. Thanks Albert
The "ideal" rode allows 7-1 scope for windy or choppy conditions--the more chain, the less scope is necessary up to a point (like 5-1 for all chain). 7-1 is generally considered a standard for a rode with chain approximately the length of the boat. So, 140' can be considered best in only up to 17' of water (factoring in the height of your bow). That's why many people carry 200' of rope with something like 25' of chain. But it depends on your expected worst case.
Now, in a crowded, protected anchorage, you probably won't have room to use 7-1, and may only go with something like 4-1, but you want to be prepared.
Most anchor chain is hot-dipped... I haven't seen electroplated. In fresh water, hot-dipped should last longer than you do.
Dennis has the right perspective. Either choice should be ok for chain.
However, for something other than a lunch break, just about all the anchor manufactureres have been saying that the length of chain should be approximately the same as the length of the boat for boats like ours. So, 25 feet instead of four.
The only time I ever really drug anchor was about fifteen years ago one night when a lot of wind came in on us and the anchor chain was too short. I knew that a storm might reach us in the night. So, posted an anchor watch with one person awake and keeping track of where we were and where other boats were. We almost drug down on a nasty rock reef.
