I'm not completely clear on this trim control. It seems to oppose the boom vang. I understand the boom vang and the reasons to keep the boom from lifting. I'm guessing in light air it's advantageous to lift the boom and cup the sail a bit.
IF SO - does that mean you set the topping lift and then tighten the vang?
Last question - how much travel does the topping lift typically require?
The boom topping lift is really just used to hold the boom off the deck when the mainsail is doused. However, in really light air if the weight of the boom/sail is keeping the main from holding any draft, a little topping lift can be added to help support the weight and allow the main to keep shape. Under these circumstances, I wouldnt use any vang at all - just let the boom/sail rise as necessary to help keep airflow attached around the main. If the rise is caused by chop, a little vang pressure would keep the boom from wallowing more than the boat, but you need to decide which is better for keeping the airflow on the sail.
The topping lift is cast off while sailing. How you do that depends on how your topping lift is rigged. I think 6-10" of slack lets it pull back from the roach without worrying about it getting wrapped on the backstay. As you figured out, the advantage to this type of topping lift is that you can use it for light air sail adjustment. I think raising the boom as much as 12" is conceivable.
With one exception, I only use the topping lift to support the boom when raising sail or when reefing. The vang I use downwind to keep the boom from raising. Upwind I generally have the vang off. I generally don't use the vang to flatten the sail, I use halyard tension and outhaul for that. In heavy seas the vang keeps the boom from pumping.
The one exception is down wind or off the wind in light air and flat seas. The vang is not really needed. I might in this condition ease halyard, outhaul and take up on the topping lift one inch or two. I have preventers for my main on port and starboard which somewhat take the place of the vang.
I'd never see a situation where I wanted to take up on the topping lift and down hard on the vang, these actions would cancel each other out.
Most times my vang is just slightly snug to prevent radical boom movements.
Until I installed a bimini, I had the topping lift adjusted so that it kept the boom just overhead with the sail down (standard rig), and stayed slack with it up. With the bimini, I wanted to be able to raise the boom at the dock to keep the sail cover off the bimini, so I installed an easier-to-use topping lift adjuster based on Jim Baumgart's (which I used the day his boat caught fire five miles out...) A little jam-cleat-fiddle block and a stopper knot did the trick. I never <i>intentionally</i> used the topping lift to cup the sail.
Another use of the lift is to raise the boom out of the cockpit enough to not bash your head against it at anchor/mooring/dock.
Otherwise, while sailing, flatter sail = less power, fuller sail = more power. When it's blowing hard and you want to depower the sail without reefing, use the vang to pull down on the boom and flatten the sail. By the same token, when the wind is light, you can raise the boom via the topping lift to get more power. It really helps that my new main has telltales attached to the leech. Using the mainsheet, traveller, outhaul, vang and lift, I can make all four telltales stream aft. Well, for a few seconds, anyhow.
