 swing keel
rustynail
Initially Posted - 08/05/2007 :  18:37:14  Show Profile
I have a 25 catalina with a swing keel. My problem is this. Last week when I tried to crank the keel up all I got was cable. I am aware that I will have to haul her out but can anyone tell be where I can get a new cable and possibly new crank as well.
newell
Response Posted - 08/05/2007 :  18:56:00  Show Profile
Your best bet is to go online to Catalina Direct. They have enough parts to build a Catalina from scratch!
newell
Response Posted - 08/05/2007 :  21:14:08  Show Profile
If you are lucky and can fasten small items under water and depending on the damage, you might be able to reconnect the cable to the keel going under with mask ans snorkle, but a scuba tank would be better.
Happy D
Response Posted - 08/06/2007 :  05:37:30  Show Profile
I purchased mine from the Catalina Factory. They had, by far, the best price including shipping from California.
818-884-7700
Response Posted - 08/06/2007 :  09:51:03  Show Profile
Just a suggestion - While replacing the cable, it makes good sense to check the turning ball and pin and replace everything at once. FYI, it's advised to replace the lift cable every two years, especially in salt water.
sweetcraft
Response Posted - 08/06/2007 :  23:49:44  Show Profile
Yes, good schedule. The Forum has stories to share about the boats that broke their cables and broke the hull.
stampeder
Response Posted - 08/08/2007 :  11:10:56  Show Profile
If by 'crank' you mean the winch. Catalina replacement winches are inexepensive and a fairly easy item to replace. Stick with Catalina sanctioned parts.
