 mast lights connector
SEAN
Initially Posted - 10/22/2007 :  18:10:15  Show Profile
I know this isnt the best picture but does anyone know were to get the black 4 wire quick connect ?
I checked the some catalogs no luck .
The problem is the lights would go on a second after you turn them on ,
then two seconds after time , now they dont work .
so I took it apart cleaned , and reconnected every thing .
it worked fine for awhile . if you wiggle it it goes on and off ,
so I figure replace it if I can .
Bubba
Response Posted - 10/22/2007 :  18:31:03  Show Profile
Sean,
You can get 'em from Catalina Direct:
Click for [url="http://www.catalinadirect.com/index.cfm?fuseaction=product.display&Product_ID=205"]<font size="3">black plastic</font id="size3">[/url] or [url="http://www.catalinadirect.com/index.cfm?fuseaction=product.display&Product_ID=289"]<font size="3">chrome</font id="size3">[/url]
Response Posted - 10/22/2007 :  18:44:07  Show Profile
If you get the plastic version buy a couple. They don't last long.
Tom Potter
Response Posted - 10/22/2007 :  18:46:30  Show Profile
Sean,
Once you get your new deck light connector, pick yourself up a tube of [url="http://www.etrailer.com/mm5/merchant.mvc?Screen=PROD&Store_Code=E&Product_Code=11755&Category_Code="]electrical grease[/url] and use it on the connections. It helps keep the corrosion away. Also good to put on your trailer electrical connections and around your trailer bulbs. Most hardware stores will carry it.
Edited by - Tom Potter on 10/22/2007 18:49:17
SEAN
Response Posted - 10/22/2007 :  20:13:37  Show Profile
Thanks guys,
ya the boats out , summers over for me !
lots of time, and steady ground for all the fixins !
Steve Blackburn
Response Posted - 10/22/2007 :  20:52:50  Show Profile  Visit Steve Blackburn's Homepage
You can also fill it up with epoxy or fiberglass like I did. Better than new.
Edited by - Steve Blackburn on 10/22/2007 20:53:06
SEAN
Response Posted - 10/24/2007 :  15:39:15  Show Profile
somebody emptyed a tube of silcone in the hole ,
it was pretty tuff to get out with out breaking !
Response Posted - 10/24/2007 :  15:49:07  Show Profile
Catalina filled the hole with silicon.
