 Capri 25 Specific Forum
 Depth Transducer
1981capri
Initially Posted - 12/27/2007 :  12:38:52  Show Profile
Has anyone tried an in-hull depth transducer on a CP25? They say they work on solid fiberglass, but not on "cored hulls", meaning wood or foam core I assume. The Capri hull lamination uses the fiberglass coremat and is solid resin, but I don't know if it would affect the "shoot thru hull" transducer.
Edited by - 1981capri on 12/28/2007 17:00:30
Response Posted - 12/27/2007 :  15:30:08  Show Profile
Dan,
From what I've read and heard it does effect the readings if shooting through a cored hull, but then again, I haven't stayed in a Holiday Inn Express in a while. :):):)
'89 SR/WK #5862
Kemah,TX
Response Posted - 12/27/2007 :  15:45:25  Show Profile
I think Coremat (if that's the product you're referring to) has something like microspheres imbedded in it, so in effect it has thousands of little bubbles--probably not a good bet. The builder of my boat, which has one layer of Coremat but no other coring, said thru-hull transducers don't work well in their hulls.
Edited by - Dave Bristle on 12/27/2007 15:48:33
chuck leonard
Response Posted - 12/28/2007 :  11:53:50  Show Profile
I installed an in hull transducer in my capri 25. I just drilled a hole to the core and cleaned out the core. Then I filled it with west system epoxy and the transducer. It has been working fine for five years.
Chuck
1981capri
Response Posted - 12/28/2007 :  16:59:30  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I just drilled a hole<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Chuck - Do you remember what size hole you needed to drill?
chuck leonard
Response Posted - 12/28/2007 :  20:01:46  Show Profile
Dan,
I am having some computer troubles so I hope this gets posted. The Standard Horizon depth sounder came with a transducer that was meant to be installed inside the boat. I used a holesaw with a short mandrel that was larger than the transducer to cut through the first layer of fibreglass and then cleaned out the foam until I reached the inside of the outer layer. Once I had the hole cleaned out and roughed up I mixed the epoxy being careful not to have any bubbles. I put about 1/4 inch of epoxy in the bottom of the hole and then placed the transducer in the hole. I used the west system just by itself without any silica or microballoons. I then filled the hole with the epoxy and it worked very well ever since. When I can get at my boat I can send you a picture if you want. It is beneficial to try to get the transducer as level as you can. I hope this helps.
Chuck
