 rudder vibration
tackingabout
Initially Posted - 01/29/2008 :  20:33:18  Show Profile
Hi, First year with my c-25, i noticed a helm vibration/shake. Now with boat on the hard i was looking a the rudder close. it has a high spot in center running veritcal. THe rudder is solid, no cracks or obvious damage, i am sure this is producing the shake. any one have this issue, any suggestions for a fix, i was thinking of sanding down the high spot and re painting, or perhaps laying new glass in the low spots and essesntially re shaping .. any suggestions would be helpfull thanks. I have a rare 1986 with diesel engine, and think the c-25 is a fantastic set up.
scott truhart
Response Posted - 01/29/2008 :  21:18:46  Show Profile  Visit Champipple's Homepage
Take a look at the pintles and gudgeons - there is a good chance those are not a snug fit anymore which could cause cavitation while underway. It is a much cheaper fix. The high spot sounds odd - any pics?
Response Posted - 01/29/2008 :  21:19:16  Show Profile  Visit Champipple's Homepage
Oh, and Welcome!!!!!!!!
Response Posted - 01/29/2008 :  23:03:44  Show Profile
I've noticed my rudder does the same thing. It "wiggles" back and forth. I hadn't thought about the gudgeons and pintles. I know there is some slack in that area. The bushings are probably worn out.
Until now I just assumed I had some mud stuck to the bottom of the rudder. My slip is shallow and the boat sometimes touches the bottom.
tackingabout
Response Posted - 01/30/2008 :  08:06:46  Show Profile
thanks for the reply, i am thinking helm wiggle is a better description of the issue, i seem to have the upgraded pintle/gudeons and yes there is some wear and space there, probabbly wouldnt hurt to replace, however i really think that "high spot" in the rudder has to cause turbulent flow across the surface of rudder thus producing the wobble, and perhaps even drag.. i walked the boat yard and saw several much older c-25 and none had this rudder inbalance. i will try to post a pic of the rudder, its not really rediculous looking to the eye but not true . I am a former hobie 16 racer and use to have to tune the rudders to elimante vibration and hummming, of course we flew at 22kts not 5 like on the c-25.
Response Posted - 01/30/2008 :  08:31:29  Show Profile  Visit Frank Hopper's Homepage
I will bet on galled gudgeons. What year is your boat?
Response Posted - 01/30/2008 :  12:17:01  Show Profile
I had a problem with worn gudgeons which created rudder "slop". I drilled them out enough to hammer in bronze bushings bought from Ace Hardware. Rudder action is now smooth and quiet.
Ed Cassidy
Response Posted - 01/30/2008 :  12:36:30  Show Profile
Is the wiggle noticed only under power or under sail or both? I'm guessing that propwash from the inboard diesel is the cause.
Ed
Response Posted - 01/30/2008 :  13:13:53  Show Profile
Ed,
Now that you mention it I haven't noticed the wiggle while under sail. I have an outboard though.
I'll have to look for it the next time I'm out. Hopefully Saturday, it's supposed to be Partly Cloudy anr 72 degrees.
Response Posted - 01/30/2008 :  13:29:44  Show Profile  Visit Champipple's Homepage
you can get bushings from CD for a under 3 bucks. Talk to Tech support first to make sure the gudgeons you have are the right size to take the bushings...
Response Posted - 01/30/2008 :  13:55:32  Show Profile  Visit Frank Hopper's Homepage
Gary, you have a balanced rudder, there is a fairly close tolerance to fitting it to the boat. The rudder must be turned and set on the gudgeons while turned. The new gudgeons with bushings fro CD will work for the upper gudgeon but if you use one on the bottom you will not be able to get your rudder back on, you need the non-bushing replacement from Catalina Yachts for the lower. So you will need to buy two pair unless they will break up a set.
tackingabout
Response Posted - 01/30/2008 :  15:28:29  Show Profile
boat is 1986, and the issue occurs under motor or sail. after closer look i see only the lower gudeon is the upgraded type, the upper is orginal, apparently to replace this i need to make a hole in front side of transom to access the bolts, CD has a deck plate kit for it, so i will likely replace the upper and lower as a pair , if this works wont bother to try to re surface the rudder, any one know how to post the pictures i took to this site
Response Posted - 01/30/2008 :  17:32:40  Show Profile  Visit Champipple's Homepage
I was able to get to those bolts through the quarterberth in my 78
Response Posted - 01/30/2008 :  20:25:12  Show Profile  Visit Frank Hopper's Homepage
I used the embedded brass plate and the old screws on the upper, I have never understood everyone's aversion to the factory method. If they were strong enough that the gudgeon wore out before they came loose then I figure they are ok. I might feel different if I were blue water.
Response Posted - 01/30/2008 :  22:26:17  Show Profile
I felt a distinct flutter with the original, unbalanced rudder. It went away completely with the balanced rudder, which had a very different foil shape with a rounded forward edge--supposedly a NACA foil--compared to the sharp edge on the original (pre-1988) blade. I had no bushings in the gudgeons with either. I can't explain it--just report it.
Edited by - Dave Bristle on 01/30/2008 22:27:21
Jefffriday
Response Posted - 01/31/2008 :  18:42:43  Show Profile
There must be something a little different with Frank's boat than mine. I replaced both upper, and lower gudgeons with the new style with bushings from CD, and had no problem getting my rudder on (She is a 89 with the balanced rudder). As for the vibration, It is probably worth checking the "high spot" for delamination. You can tap the area on and around the spot with a coin an hear if there is anything wrong. I just finished repairing two 4 or 5 inch diameter blister/delamination areas on mine from letting it be exposed to direct sunlight for a few hours.
Response Posted - 01/31/2008 :  18:50:16  Show Profile  Visit Champipple's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Jefffriday</i>
<br />There must be something a little different with Frank's boat than mine. I replaced both upper, and lower gudgeons with the new style with bushings from CD, and had no problem getting my rudder on (She is a 89 with the balanced rudder). As for the vibration, It is probably worth checking the "high spot" for delamination. You can tap the area on and around the spot with a coin an hear if there is anything wrong. I just finished repairing two 4 or 5 inch diameter blister/delamination areas on mine from letting it be exposed to direct sunlight for a few hours.
Part of what we, as well as any other used boat owner, have to deal with is the fact the the DPO might have made modifications for any number of reasons. Additionally, because we are not a strict one design class Catalina could have made a change mid model year. No reason or explanation required. It's not like they have to shut the plant down for retooling - they just tell Fred and Earl the new process over coffee at the morning meeting. Ergo, there very well could be something different between the two boats.
jmoritz
Response Posted - 02/05/2008 :  11:11:29  Show Profile
I have the same rudder vibration and have never been able to figure it out. I also have the inboard diesel and wondered if it contibuted. I get the vib. under power or sail. I even built a balanced rudder from the plans on this forum and still get the vibration. There is a very small amount of play between the pintles and the gudgeons but I have never had a boat do this before.
Response Posted - 02/05/2008 :  20:20:19  Show Profile
John, I'm suspicious your saildrive is creating some turbulence around the rudder, whether the prop is turning or not. My only other thought would be to add nylon bushings to the gudgeons, which might require opening up the holes just a bit.
