 How do you carry your tender?
JD van Wyhe
Initially Posted - 08/16/2002 :  10:45:08  Show Profile
We'll be sailing from San Pedro to Catalina Island later this month. I've made arrangements to borrow an 8' inflatable with outboard. Never used a tender before. Should I tow it; or lash it onto the foredeck?
JD van Wyhe
C25 Marea #139
jellyfish
Response Posted - 08/16/2002 :  10:49:21  Show Profile
IMHO that would depend on the weather and the seas!
Douglas
Response Posted - 08/16/2002 :  11:27:11  Show Profile  Visit Douglas's Homepage
How long is it ? How heavy is it ? I tow when I travel. 8' Walker Bay. I stow it on the forward deck when in the slip. It takes up the whole area. I can still open the forward hatch though.
Doug&Ruth
Wind Lass
Tacoma Wa.
Response Posted - 08/16/2002 :  13:26:53  Show Profile  Visit Champipple's Homepage
I usually pull it right behind the engine, so the coal is right within reach to put in the furnace.
<img src="http://www.trackwalker.ca/Train/Locomotives/5931rr.jpg" border=0>
Any time I've had a dink its on a painter behind the boat.
RichardG
Response Posted - 08/16/2002 :  17:06:48  Show Profile
Duane:
What's the theoretical hull speed of your "tender"?
JD:
How will you be transporting it down to SoCal? Assuming you will deflate it, I would not re-inflate it until you get to Catalina. If you aren't going to deflate it while trailoring (putting it in the back of a pickup?), towing it about 10' behind the transom usually works fine this time of year. But I wouldn't recomend towing it with the engine on. Also, I prefer the yellow polypropylene rope for a painter because it floats which helps prevent getting it wrapped in the prop while arriving or leaving your mooring or dock.
Sailynn
Response Posted - 08/20/2002 :  01:04:03  Show Profile
We just returned from a Pacific Northwest trailering trip. Have a West Marine 8.5' inflatable with slat floor boards in a valise which was lashed in front of the mast until we inflated it. No motor. Our friend had a 9' with rigid floor boards and lashed it to the stanchion opposite the head window. In heavy winds, towing it to Catalina Island is stressful and in light winds, it's a "drag". I would go with lashing it to the top of the boat.
Gary B.
Response Posted - 08/20/2002 :  12:28:50  Show Profile
Some inflatables have a "keel" of sorts that helps them track through the water much better than those with flat floors. They would tend to have less drag. If the ob is small enough and light enough, say 3 hp or so, consider putting it on a bracket attached to the stern pulpit, so as not to take up valuable storage inside the boat. If the boat will track, w/o too much drag, and the conditions permit, towing is a fine option. If it proves to be a "drag" , consider putting it on the foredeck inflated so it's ready for use if you need it. If you don't care for these options, then I'd deflate it. The idea of a valise or bag lashed by the mast would seem to make sense. I never like mine buried in a locker if there's a chance I may need to use it.....
Gary B.
Encore! #685 SK/SR
Response Posted - 08/21/2002 :  13:32:24  Show Profile  Visit Champipple's Homepage
Duane:
I would have to say, roughly of course .00002 knots but thats only if I pay out enough painter to let her surf the wave's behind me....and..I have to empty out all the coal.
Duane Wolff
"The Flying Wasp"
C-25, #401 std,sk
<img src="http://im1.shutterfly.com/procserv/47b1ce23b3127cce9b043565af3d0000004010" border=0>
MattL
Response Posted - 08/23/2002 :  02:59:48  Show Profile
JD,
If you look at the computer before you leave have a great trip. If you see this upon return, I hope you had a safe and fun trip.
Matt/Brigitte Loeffler
E.C. Rider
Cat 25 86'
FK/SR _/)
