I just got my reconditioned sails back from Sail Care. They look great. I got out in the front yard just now to put the battens back in. This is a fully battened main for an 84 Catalina 25 tall rig. The (expletive) things are too long to go back in. There is no flap on the open side of the pocket. The batten sticks out at least 1.5 inches when it is FULLY pushed into the pocket. There is a plastic piece on the opposite side of the pocket and I removed one to be sure the batten was all the way in the pocket. To get the batten in far enough to close the unsown end it would have to bow quite a bit. Having only two hands doing this and re-sowing the pocket is impossible. I think the reconditioning may have shrunk the sail somewhat.
This is Sunday and the Sail Care guys are off today. I sent them an email asking if they have any suggestions. Being the impatient individual person I am I’m posting here before they can respond.
The only idea I have is to sail the boat without the battens in the pockets. Maybe there would be enough stretch after a couple of good sails to get them back in.
As always I am open to any suggestion.
Thanks Steve
Summer's Eve #4489 1984 Catalina25 Tall Rig Eagle Mountain Lake Fort Worth, Texas
Shorten the battens. Put them in in vise and cut with a hacksaw. Sandpaper/grind/rasp so the cut end is smooth and rounded. Buy some new battens if/when the sail stretches out again.
Aren't the battens supposed to sit inside the plastic fittings at the luff? Maybe you should have velcro straps added so you can adjust them as the sail stretches back out, and it will. I am not a fan of sail reconditioning, when was the last time you bought retreads for your car or put a tube in a bad tire? I think it is better to go another year or two and buy new sails.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Frank Hopper</i> <br />...I am not a fan of sail reconditioning...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">But Frank... That way you can have bright, white, crispy, blown-out sails!
Steve and Val, I'm sorry that you've had a bad experience with Sail care. This is interesting. I've used Sail Care several times over the past 20 or so years, and have never had a bad experience with them. The last time was when we sent the main and 150 to them after we bought the C-25 in the fall 2006. They came back looking great, and I'm sure that we'll get several more years of use out of them.
These are fiberglass battens. They’re about ¾ of inch wide and about 3/16 thick. I have never sawed fiber glass before. I’m guessing a little tape at the point of the cut would be a good idea, to prevent splitting. A brand new hack saw blade too.
I had my sail 'reworked' they didn't clean it, they (north sails) just worked on it to make it function better. Looks like I may have made the right choice by going the re-work route rather than the recondition route.
When I was a hard core windsurfer, I had 7 or 8 sails at any given time. When I used a sail infrequently - there were often batten issues. So, as a fix on difficult sails I would have velcro sewn in at the openings of the pockets. Generally speaking, when the sail got loosened up with use, I would be able to push the batten in all the way, then tighten up the velcro. I had also used a twin ring locking system that was a little more effective. (like a belt with two rings in which you pull the working end to tighten)
Steve, those sound like fairly thick battens, almost a quarter inch. Tape sounds like a good idea. I would select a very fine tooth blade, like for metal pipe, and use short light strokes, not much more than the weight of the saw itself. However, the hardware guys may have a better idea. I would also try to go all the way around the batten with the blade, if you can line it up right, i.e. score the underside before cutting all the way through. Might keep the edges cleaner. Then give it a thorough sanding to smooth the edges. then see if it will go back into the plastic fittings.
