 Halyard replacements
quilombo
Initially Posted - 03/21/2008 :  06:22:17  Show Profile
Hi guys,
has anyone replaced all their halyards, if so, can you give me an approx cost on good quality halyards,
thanks
mine look a little discolored and a couple are slightly frayed, and can they be done while the mast is up?
just curious as to what I'm looking at money wise,,
Edited by - quilombo on 03/22/2008 08:00:22
Response Posted - 03/21/2008 :  09:11:27  Show Profile  Visit Frank Hopper's Homepage
Study up at Layline.com
Response Posted - 03/21/2008 :  12:13:55  Show Profile
Are yours all-rope or the original wire-to-rope? If the latter, you probably need new sheaves at the masthead to fit the rope size you pick (commonly 5/16"). I see from your pic that they're led back to the cockpit, so they're probably all-rope replacements. Catalina Direct is a reasonable source, has good low-stretch, pre-spliced halyards, and knows the lengths. Be sure what you get is right for your clutches.
Response Posted - 03/21/2008 :  12:28:59  Show Profile
Catalina Direct has kits for wire/line and all line halyards, West Marine has pre-made wire/line halyards, both standard lengths and custom, and Rigging Only can fix you up with anything, so there are many venues for price comparison. I got masthead sheaves for all line conversion from CD and 70 ft of 6mm and 8mm New England Rope V-100 and eye spliced the ends. After I did the main and saw how slippery the vectran core is, I did a tapered and tucked cover with a core to core splice on the jib halyard. I should probably redo the main that way, but I'll wait and see if the main falls down.
mcollard
Response Posted - 03/21/2008 :  13:56:01  Show Profile
I replaced mine last year with 5/16" Sta-Set X line, which I believe is a common choice. $61.00 plus $11.73 shipping for a 65-foot halyard, shackle not included, from Milwaukee Rigging eBay store. If you run lines aft you probably want 75 feet. If you currently have wire to rope halyards, figure in the cost of replacing the masthead sheaves, which you can get from Catalina Direct, in order to go all line, which is recommended.
quilombo
Response Posted - 03/23/2008 :  07:16:49  Show Profile
whats a sheave,,,
Response Posted - 03/23/2008 :  08:03:37  Show Profile  Visit OLarryR's Homepage
Samson XLS Extra T is another option. I recently replaced my main and genoa sheets with this line and it is also recommended for halyards. Defender Industries offers decent cost/ft on this line compared to other distributors. Here is the link to the Defender info - you have to insert the whole string into your browser to come up with the Defender info:
http://www.defender.com/product.jsp?path=-1|118|311417|314169|749715&id=749142
Edited by - OLarryR on 03/23/2008 08:05:29
Response Posted - 03/23/2008 :  09:28:08  Show Profile
Larry,
Try using the Prompt format mode. It allows you to insert links such as yours.
[url="http://www.defender.com/product.jsp?path=-1|118|311417|314169|749715&id=749142"]Defender Samson 5/16 " XLS Extra T[/url]
Response Posted - 03/23/2008 :  09:32:05  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by quilombo</i>
<br />whats a sheave,,,
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">a wheel with a grooved rim, such as is mounted in a pulley block to guide the rope or cable; pulley wheel
Response Posted - 03/23/2008 :  17:48:24  Show Profile  Visit OLarryR's Homepage
Don,
What's the prompt format ? I tried the hyperlink symbol on the reply screen and that only captured part of the url.
Edited by - OLarryR on 03/23/2008 17:49:43
Response Posted - 03/23/2008 :  18:56:05  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by OLarryR</i>
<br />Don,
Before clicking on the hyperlink symbol, change the "Format Mode" (upper left of the blue box) from basic to prompt. Once that is changed, click on the hyperlink and follow the directions.
Response Posted - 03/23/2008 :  20:22:49  Show Profile  Visit OLarryR's Homepage
Let's see if this works -
[url="http://www.defender.com/product.jsp?path=-1|118|311417|314169|749715&id=749142"]Sampson XLs Extra T[/url]
Hey ! It does work ! Thanks !
Edited by - OLarryR on 03/23/2008 20:28:30
Response Posted - 03/24/2008 :  07:28:06  Show Profile  Visit Frank Hopper's Homepage
For simple definitions I use google
define sheave
