 Zoom
arlingva
Initially Posted - 08/26/2002 :  20:29:48  Show Profile
Just wanted to let you guys who have complained about the 250's performance that I don't have any. Sailing yesterday in 9 knots of breeze with full main and 110 jib and blew by an apparently well sailed (sails not luffing in the breeze)Hunter 320 like she was standing still. I also had a total novice on the help while we were tacking up the channel. I'm sure the boat gets overpowered when the breeze goes up, but like the forum users say reef early and you'll be happy.
Bill Swanson, C-250WK #614, [still unnamed]
Bill Swanson
C250WK #614
ssteakley
Response Posted - 08/26/2002 :  22:27:05  Show Profile
Bill,
you said what we all know, The 250 is a light, quick boat and when sailed properly it can hang with any cruiser and compete with any racer/cruisers of comparable length. The thing about our 250's is that everything makes a noticeble difference and if you can sail a 250 well then all other boats in her class are simple. What a great boat to learn on!
Steve Steakley
Moon Chaser #385 WK
bill bosworth
Response Posted - 08/28/2002 :  08:57:58  Show Profile
Bill Swanson
C250WK #614
bill bosworth
Response Posted - 08/28/2002 :  09:05:45  Show Profile
Bill;
We had a similar experience a couple of weeks ago. We had two reefs in the main, 15 to 20 knots of wind. As we were tacking down the lake we found a Hunter 30 wating for us, as we passed he joined into a tacking duel. We beat to wind for about 45 minutes, the Hunter couldn't catch us, we both turned down wind and to my suprise we walked away from him. Once we stopped to talk, the Hunter owner wanted to know more about the boat and the water ballast system, could we have a new convert?? We've been very supprised and pleased with how well this boat performs, as you said, reef early, it doesn't hurt the speed at all.
Good sailing
Bill, Serendipity c250wb, 134
arlingva
Response Posted - 09/02/2002 :  21:24:18  Show Profile
I do have a speed question. Sailing today dead downwind (not my preference, but that's where the channel was)110 jib didn't want to stay wing and wing. Found when I came up about 10 degrees and broad reached jibing back and forth across the channel speed came up significantly. Is this the prefered method (fastest)?
Thanks, Bill C 250WK, # 614
Bill Swanson
C250WK #614
bill bosworth
Response Posted - 09/02/2002 :  23:16:06  Show Profile
Bill;
When we know that we will be sailing down wind for any length of time we rig a wisker pole, it is easy to install, some have added tracks and a ring to the front of the mast, I just have two eyes, one on either side of the mast.
Your method of tacking down wind, so that you can keep on a broad reach, is a good one.
Bill C250wb #134 Serendipity
Response Posted - 09/03/2002 :  14:39:35  Show Profile
Bill Swanson,
The general rule for sailing downwind is that you should run downwind in the puffs, with your sails set wing-and-wing, and you should broad reach in the lulls. When your sails are "wung out," you should set the whisker pole, as long as the wind is not so strong as to break the pole.
The rationale is that, a strong wind will push your boat downwind at maximum speed, enabling you to sail the shortest distance toward your downwind destination in the shortest period of time. When the wind becomes light and you are running downwind, your boatspeed drops drastically. By broad reaching when the wind lightens, you keep the boat's speed up. When broad reaching, you are jibing back and forth downwind, and travelling a longer distance to reach your objective, but you can cover it at a higher speed, and in less time.
My personal opinion is that you should only begin to broad reach when the wind becomes extremely light. Until that point, most boats make better progress toward the downwind destination by sailing wung out, even though it seems excruciatingly slow.
Response Posted - 09/03/2002 :  17:15:21  Show Profile
Bill - even when running downwind, don't go directly downwind! It's the slowest point of sail. A faster way when "wung out" (as Steve says!" is to keep the windex arrow pointed over the corner of the transom (with the tab aimed at the main, we don't want any of that "sailing-by-the-lee" stuff!). In this way you still generate a little lift across the main AND the poled-out genoa.
Derek
arlingva
Response Posted - 09/03/2002 :  22:24:11  Show Profile
Next dumb question
Where do I get the wisker pole? What size? Suggested height for mount on mast?
Thanks, Bill
Bill Swanson
C250WK #614
ssteakley
Response Posted - 09/03/2002 :  23:26:59  Show Profile
I suggest an adjustable 7-17' whisker pole. Mount a 4'X 1" track on the front of the mast and a car with a (spinaker type) ring. the track can later be used with an asymetrical spinaker or reaching sail. The pole should remain level so you just have to experiment with your jib/Genoa to determine the best placement for the track. West Marine will be glad to sell you the pole you need. Sailing wing on wing without a whisker pole is not near as much fun......more fun........more money!,
Steve Steakley
Moon Chaser #385 WK
Edited by - ssteakley on 09/03/2002 23:29:19
MattL
Response Posted - 09/04/2002 :  03:03:04  Show Profile
Bill,
Nothing about anything in your letter, except for your salutation.
Instead of noname, how about Swansong
Matt/Brigitte Loeffler
E.C. Rider
Cat 25 86'
FK/SR _/)
Response Posted - 09/04/2002 :  10:52:51  Show Profile
Anything that is made specifically for use on a boat is usually exorbitantly priced. Compare, for example, the cost of a Kroger's mop vs. a Yacht mop.
I bought two Forespar piston clip fittings that are used on the end of a whisker pole, and fitted them to the ends of an aluminum and fiberglass telescoping paint roller handle of appropriate length, and it makes a great whisker pole, and cost considerably less than if I had bought a complete Forespar pole. I don't recall the brand name of the roller handle, but one end is yellow with black trim, and the other end is aluminum finish, and I see them in most of the big Builder's Square-type stores. Some come with a twist-locking extension, and others come with holes drilled through the pole and a spring-loaded button that locks the telescoping extension. I use the latter type, and like it very much. If the pole breaks, I can re-use the piston clip fittings, and attach them to a new paint roller stick for about + - thirty dollars.
arlingva
Response Posted - 09/09/2002 :  22:13:55  Show Profile
Steve, I like Swansong. I have two kids and the early family favorite is Hakuna Matata (a disney song from the Lion King) according to disney it mean's "no worries for the rest of your life."
I'll keep you posted.
Bill Swanson C 250 wk, #614, [still unnamed]
Bill Swanson
C250WK #614
