Has anyone converted the early (i.e. hull 97) stove butane canister with a Coleman propane (camp stove style) bottle with regulator and quick disconnect? I've seen the 1 gal. propane in the fuel locker with hoses going everywhere--not interested. I just want a simple replacement for the leaky and troublesome canisters.
Ron, yes... the rinky dink cannister was a very quick item to go. There are a couple of options, the easiest is to remove the cannister unit but save the male quick couple connection.
Find a coleman adapter that the coupler can be married to. You may find this at Academy sporting goods or a home center. These will have a valve and employ a very small hole in the shaft that enters the cannister...this serves as the regulator (sort of crude but it works)for simple use.
This simple conversion should be accompanied however by some discipline... that is to store the cannister in the fuel locker with the gas. Just quick connect for use when using the stove.
I have used mine a great deal like this and it doesn't seem to be much hassle to get the cannister and hook up. Quick couples do wear out eventually however...so monitor any leakage problems.
The harder route which I eventually will adopt is to run a line to the starboard coaming box and let the cannister reside there. This would have the advantage of doing away with the quick couple as enough line slack would allow screwing on the cannisters and then sliding the line back into an access hole. Again, the valve would need closed each time used or better yet... remove the cannister. Craig Osterlo and I discussed this mod...and he called and visited on the phone with Coleman about the use of their cannisters in a horizontal position.... and they said...no problem.
Two Coleman cannisters will easily provide all my needs for grill and stove for 10 days or so cruising. And, because of the grill, the cannisters are needed anyway so this seems a reasonable approach compared to a dedicated tank, regulator, valve assembly etc.
There is storage space above my 6 gal galvinized Tempo gas tank and the gas locker serves a safe storage place as its vented well with lower drains and fresh air intake. I wouldn't be tempted to install a line to the gas locker and leave the cannister there for use which might be done if using a 3 gal gas can unless done so without making a hole in the bottom of the locker. This would mean routing the line out of the fresh air intake and back into the hull via steering arm boot if wheel equipped or some other method.
