 Outboard bracket handle
Sidurian
Initially Posted - 08/28/2002 :  17:34:15  Show Profile
The original outboard bracket is out of alignment due to....whatever....and I'm having a really hard time raising and lowering the unit. It looks like the bolt going through (not the handle itself) the bracket is bent - I tightened all the other bolts down a bit in the hopes of straightening the unit but it's hard as hell to crank it up.
As usual - all suggestions are welcome except I'm not inclined to install a new unit (garhauer or whatever).
There's always something!
Response Posted - 08/28/2002 :  21:10:21  Show Profile
Stephen,
Seems that you have the symptoms tied to the cause. I'd try taking the bracket apart and straightening any bent components.
BTW, if it's a Garhauer bracket, they'll rebuild it for you, or sell you spare parts, including beefed-up components.
