I have a great roller furling unit that came with the boat.
I have put up the mast, and tunded the rigging to the best of my ability.
I am wondering how much play (ie how loose) the forestay and roller furling should be. I have cranked the backstay as much as it can possibly be tightened, yet am still concerned with the amount of play in the forestay/roller furling.
At rest, mine has a fair amount of play in it. I keep the backstay and forestay with less tension when I am not sailing. Like Frank, when I am sailing, I tighten both backstay whioh adds tension to the forestay as is necessary to get good sail shape.
Chuck: How much play is it that you're concerned about? In a good breeze, if you sight along the mast and forestay, how much of a bow (displacement at the midpoint) do you see? That's the primary issue.
Two issues may be involve if you've tightnened that backstay as much as you can. First, your forstay may need to be tightened as well. You may not be able to tell unles you remove the drum. Second, it's possible that your aging stays are stretched and need replacing.
You may want to check your lower shrouds- if your backstay is fairly tight but your forstay remains loose, your forward lower shrouds may be too tight to allow the mast to move back and tension the forstay. C-25's don't have a terribly flexible mast.
When the backstay is on tight the forestay should be very tight. No sag means a boat that points well. When the backstay is off the forestay should be wagging around like a limp noodle - 4 to 6 inches of play. Lots of sag means a boat that goes downwind well.
Set the forestay tension with the backstay medium and the lowers slack. Then tension the backstay. The mast will bow. Ease the backstay a little and adjust the lowers to pull out the bow. Verify that with the backstay off the forestay is quite loose.
When sailing in a good wind the leeward shrouds should be slack but not loose, there should be no visible sag in the forestay.
Frank's advice is good for an inland lake with winds routinely above 30.
Mine is better for winds usually 10 to 15, and I copied from the master, Steve Milby.
Absolutely, my comments are always predicated on the presumption of high wind, I rig for an average of 20 mph, if I sailed Canyon lake I would do exactly what Derek does. We have been blowing in the forties today, and it might get windy tomorrow. If I were on the water today I would be running about 40-60% headsail and nothing else.
