 Lee helm in light wind?
Initially Posted - 06/11/2008 :  08:23:12  Show Profile
In the few years that I've owned the boat I guess I have not played around with this. While sailing yesterday, on a beam reach, in light wind, moving along at about 3 knots, I just let go of the tiller. The two or three times I did, the boat wanted to turn down. I can say I don't remember any lee helm in stronger winds, but I have never just let go of the tiller like this. I have a standard rig, swing keel and 135% furling genoa. Normal? Any thoughts?
2005 Gemini 105Mc
PO 1987 C25 #5509 SR/SK
Tampa Bay
Response Posted - 06/11/2008 :  08:55:21  Show Profile
Your helm may shift to neutral or weather in more breeze as the boat heels more--the hull shape at heel tends to induce or increase weather helm. Sail trim can also be a factor (main relative to genny), but assuming you trim somewhat equally, the helm is what it is. Check it in more breeze, and use a halyard to check the mast angle--if it's upright or forward, tune it back a little. A few degrees of weather helm is good for speed and safety.
Edited by - Dave Bristle on 06/11/2008 08:56:55
Response Posted - 06/11/2008 :  08:58:42  Show Profile
Next time it happens, try some experiments with sail trim.
In very light air the main should be 'slacked off'... outhaul eased, vang off. Sheet it out 'more than you think you should'. Adding telltales to the main really help you see draft and air flow.
If you still have lee helm, trim the jib in or out a bit and watch how the balance of the boat changes.
One of the fun things about sailing.
Response Posted - 06/11/2008 :  09:25:22  Show Profile
Not much heel yesterday, I don't think the wind was much over 5 knots. I have not checked the mast rake recently, but I do keep a little pre-bend in it. I don't have any way to adjust tension on the backstay while sailing.
Main was slacked to the point of luffing and then pulled back some. Vang off. I purchased some tell-tales for the main but have not installed them yet. Tell-tales on genoa looked good, so I'm guessing it was trimmed correctly.
Response Posted - 06/11/2008 :  09:52:49  Show Profile
It depends on what you mean by "light air." The rudder's gudgeon and pintles are affected by friction, because they don't have bearings to make them operate smoothly. When the windspeed is less than about 3-4, the forces on the sails sometimes become so slight that they can't overcome the amount of friction of the gudgeons and pintles. The tiller might <u>act</u> as if there's lee helm when, in fact, there isn't.
If that's the only time that it seems that you have lee helm, I wouldn't worry about it. If the boat occasionally bears off slightly in extremely light air, that's not a safety concern, as I see it, because the boat isn't going to wander far in those conditions, and nothing bad is going to happen quickly in those conditions.
What is important, however, is that the boat have slight weather helm when the windspeed is higher than 3-4.
In those very light airs, my C25 sometimes acted as if it had weather helm, and sometimes it acted as if it had lee helm, just because of the friction of the rudder mounts. But, as soon as the wind picked up slightly, it behaved exactly as it should have, with just the right amount of weather helm.
JimB517
Response Posted - 06/11/2008 :  13:10:48  Show Profile  Visit JimB517's Homepage
rake the mast aft 3 or 4 inches. It gets rid of lee helm.
Response Posted - 06/11/2008 :  18:28:40  Show Profile  Visit Frank Hopper's Homepage
Your sig looks like a 150, lee helm at that speed sound about right.
