 Boom Part Missing
Initially Posted - 06/14/2008 :  09:52:47  Show Profile
I have noticed that our reefing line can get fouled at the back of the boom. While sailing last night I noticed there is a small plastic piece missing from the back of the boom. Hard to see but at the top back corner of the boom's sheave extension there is a tiny hole just fore of the reefing line where the reefing line goes above the boom.
Turns out there was a plastic rod that spanned the end of that area and contained the reefing line and topping lift (I don't have one). I poked the end pieces of the rod that were still stuck in the holes.
So, I am missing a part. A friend with a 250 has the same broken pieces and suggested replacing them, at least temporarily, with a thin zip-tie. I'm thinking thin stainless steel rod.
Anyone had this problem and found the replacement item or a substitute?
Edited by - Nautiduck on 06/14/2008 09:53:47
528
Response Posted - 06/14/2008 :  17:58:16  Show Profile
Randy, recently I replaced the plastic with stainless for a quick connect topping lift. I found that my lazy jacks support the boom adequately when lowering the main. Once the main is down, the topping lift is attached. A smoother operation and very convenient if you choose to remove the boom. I never say crap anymore, after raising the mast and realizing I forgot to attach the topping lift to the masthead! This was part of my quest to simplify the rig for singlehanding, and setup/breakdown.
Response Posted - 06/14/2008 :  18:21:46  Show Profile
Sweet, stainless!
Tell me more. Is that a small diameter SS tube with a bolt inside it??
Response Posted - 06/14/2008 :  20:09:29  Show Profile
It's a solid pin. It was in my spares box. Not sure where it came from. I drilled the boom and hammered her home. I then cut the end off flush with the boom. It's not the polished end, hence what you see. I will be posting a few other mods soon. Lower stays moved, 25 gallon water tank in stern, single backstay, LED lights from Walmart($1 apiece), Nicro vent. I was thinking today, the boat has been like a helicopter lately, working on it 10 hours for every hour of sailing!
edit: Oh yea, and the gin pole for the later models, reposition of the battery, 12v outlet for ipod broadcasting to stereo, wired GPS input for radio DSC....I know there are more....
...washdown/shower in cockpit locker
Edited by - 528 on 06/14/2008 20:22:56
Response Posted - 06/14/2008 :  21:07:00  Show Profile
I'm looking forward to seeing your mods, especially the single backstay, gin pole and moving the lower shroud. I don't think I've seen anyone move a shroud.
Where/how are you attaching the gin pole??
Edited by - Nautiduck on 06/14/2008 21:07:44
AADIVER
Response Posted - 06/14/2008 :  21:22:18  Show Profile  Visit AADIVER's Homepage
Randy, get rid of that convoluted boom threaded reefing system and simplify it like this:
...and run a single line from the 1st reef luff cringle down through a block at the foot of the mast and back to the starboard clutch. Reef the luff first, then the leech; takes less than 15 seconds.
Edited by - AADIVER on 06/14/2008 21:30:08
Steve Blackburn
Response Posted - 06/15/2008 :  00:08:24  Show Profile  Visit Steve Blackburn's Homepage
Now I know what those <u>2</u> little pieces of plastic are at the end of my boom! I guess mine is broken too!
Response Posted - 06/15/2008 :  11:33:47  Show Profile
Steve, I think they are all broken. My guess is that the PO's all hooked up the pigtails to them and broke them off.
Frank, I know that people swear by the two line reefing. I am very happy with my convoluted system.
AADIVER
Response Posted - 06/15/2008 :  16:09:43  Show Profile  Visit AADIVER's Homepage
"...swear by..." And I know people who use the A word: at
Response Posted - 06/16/2008 :  00:19:45  Show Profile
OK, the part is 3/16" diameter by 2" long. I'm going to see if the hardware store has any SS pins that size.
