 Replacing masthead light
cmckitrick
Initially Posted - 07/08/2008 :  21:54:13  Show Profile
I was wondering how the cover of the masthead light is secured. It looks like there is a lot of tape wound around the bottom of mine. I am going in the water tomorrow...finally. I was going to change the bulb if I have time. However I dont want to get the cover off and not be able to get it back on. Anyone changed on lately? Thanks.
Charlie McKitrick
Norwell, MA
Valiant Lady... for now
'81 C 25 SR/FK
Response Posted - 07/08/2008 :  21:57:36  Show Profile
Charlie,
I replaced mine with a new fixture last month. The lense cover twists off with about a 1/8 to 1/4 turn. I believe counter-clockwise.
Ed Cassidy
Response Posted - 07/08/2008 :  21:58:24  Show Profile
The plastic cover on mine unscrewed about a quarter turn and then pulled off.
Ed
cmckitrick
Response Posted - 07/08/2008 :  22:02:09  Show Profile
Thanks guys. I guess I am not the only one up late thinking about my boat.
dreddick
Response Posted - 07/08/2008 :  22:22:15  Show Profile
Mine also was supposed to twist off but was taped around the base. I found that several of the tabs that were supposed to hold it on were broke off. So I taped it back on when I changed my bulb.
cat1951
Response Posted - 07/09/2008 :  08:22:26  Show Profile
I would be ready to have to tape it back on and the possibility that it is in more than one piece. We had our mast down a couple of years ago and had planned to replace the light when it was down. Lucky that we did since it had a small hole in the very top that would let in moisture when it would rain. We ended up replacing the entire light and fixture.. Got the new one from Catalina Direct.
cmckitrick
Response Posted - 07/10/2008 :  10:09:49  Show Profile
Well I got the cover off no problem but the bulb was not what I expected. I thought it was the same as the running lights which I thought is what the manual said but it was this skinny looking thing which I could not even see how to disconnect. I did not have much time as the trailer was on the way to put me in the water so it looks like this going to wait until next year.
Stardog
Response Posted - 07/10/2008 :  10:21:44  Show Profile
I don't go up the mast as much as I used to, so nowadays I replace anything questionable when I'm up there. Last time it was the bow light, the lens was looking pretty shabby. Next time up the mast I'll replace the anchor light with and LED version.
Response Posted - 08/11/2008 :  21:06:30  Show Profile
I stumbled across this light that could be used for a temporary masthead/anchor light.
http://gullsweep.com/MarineLighting.html
Response Posted - 08/12/2008 :  09:18:00  Show Profile
SWEET light ...
stampeder
Response Posted - 08/12/2008 :  18:58:38  Show Profile
those lights are a good idea - however, I suggest buying lanterns or lights that use double A or triple A batteries because you can buy rechargables. I've tossed all my stuff that uses D batteries - I find also, that A and AA batteries last longer than D's.
Response Posted - 08/12/2008 :  19:25:15  Show Profile  Visit Prospector's Homepage
Colour me cheap...
Most of the guys in our marina use the tin hurricane lamps you can buy at canadian tire for $5 as anchor lights. Tie one on your forestay at a suitable height and it meets all the requirements. Not sure how th ecost of lamp oil compares to the cost of batteries though.
mpoweski
Response Posted - 08/13/2008 :  15:36:07  Show Profile
Assuming you are talking about the anchor light, the lens is a quarter turn. When I tried to remove mine, the plastic was very crazed and crumbled in my hand. The replacement is a aqua signal size 25 which is available at West Marine or Defender.
Response Posted - 08/15/2008 :  10:36:10  Show Profile
My boat had the anchor light removed, I suppose, and I wanted both a light for anchoring and a windex light for night sailing, so I made a reflector in the anchor light I installed that shines mostly outwards with a little shining upwards.
Then, of course, on this forum I learned about mini-windexes on the shrouds, and saw them in action on JimB's boat, too. But my LED anchor/windex light is sweeeeeeeeeet.
Response Posted - 08/15/2008 :  12:58:04  Show Profile
Be careful replacing the bulb in your masthead light. Mine takes a bulb with pointed contacts. The flat or inverted contacts won't work. Had to get the bulbs at WM.
cat25
Response Posted - 09/11/2008 :  08:45:22  Show Profile
I replaced my bulb with an led one from west marine. Fit great an uses so much less electric than conventional bulb. Ken
