 Slip Cable TV connector
Initially Posted - 07/15/2008 :  19:20:28  Show Profile  Visit britinusa's Homepage
Any advice on the type of cable/connection to use to connect to a slips cable tv connector.
Is there a standard connector type?
TIA.
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
SEAN
Response Posted - 07/15/2008 :  20:49:26  Show Profile
I think its just like home stuff rg59 ,same end connectors .
but boat grade
Edited by - SEAN on 07/15/2008 20:52:33
Response Posted - 07/15/2008 :  21:27:43  Show Profile
You need [url="http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/269886/377%20710/0/cable%20tv/Primary%20Search/mode%20matchallpartial/0/0?N=377%20710&Ne=0&Ntt=cable%20tv&Ntk=Primary%20Search&Ntx=mode%20matchallpartial&Nao=0&Ns=0&keyword=cable%20tv&isLTokenURL=true&storeNum=5002&subdeptNum=9&classNum=707"]this[/url].
Radio Shack sells weather proof cable in various lengths... It's black not white, but cheaper than WM.
sten
Response Posted - 07/15/2008 :  21:51:23  Show Profile  Visit britinusa's Homepage
<br />You need [url="http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/269886/377%20710/0/cable%20tv/Primary%20Search/mode%20matchallpartial/0/0?N=377%20710&Ne=0&Ntt=cable%20tv&Ntk=Primary%20Search&Ntx=mode%20matchallpartial&Nao=0&Ns=0&keyword=cable%20tv&isLTokenURL=true&storeNum=5002&subdeptNum=9&classNum=707"]this[/url].
Might 'Want' it, but not 'need' it at nearly a boat unit!
already have a 50' coax cable with std ends, but have never taken a peak inside the slip pylons other than to connect the 110v.
Paul.
frog0911
Response Posted - 07/15/2008 :  23:39:15  Show Profile
You should be able to plug right in. The Slip should have the standard female connector same as you have in your house. The only difference is its should be in a waterproof box.
Response Posted - 07/16/2008 :  07:06:55  Show Profile  Visit britinusa's Homepage
Thanks Frog.
