I'm playing in the [url="http://www.volvooceanracegame.org/play.php"]Volvo Ocean Race game[/url]. I've been as high as 1221st place, and as low as 16700th or so. I managed to lose so many places because I didn't realize I needed to round a mark off of Brazil, so set a great circle route from the Cape Verde Islands, thought I was pretty smart until I started losing places wholesale. I've made up 9000 places since then (this isn't as impressive as it sounds). There are currently 41k boats in the race, and if you create a boat, they'll drop you somewhere along the race course (hopefully not in front of me). There are enough boats in the race that I'm pretty sure you could walk from Spain to Brazil right now stepping from deck to deck.
Edited to fix link.
It's fun & kind of addictive, I've learned a few things as well.
Make sure when you set up your boat you choose knots & miles, unless you're used to sailing in KPH & kilometers. When they first started the game you only got one chance (that I never saw), they've since modified the game so you can change now.
David C-250 Mainsheet Editor
I am now, thanks for the tip. Joined late, so they put me in at about 28,800 place 500 miles or so north of the equator, I've worked down to 25,625 in 2 days. The I'm hoping to play the tricky winds off the coast of southern Brazil carefully and jump on a low pressure heading east, but I'll have to hurry to catch it! Pretty fun. My boat is Avocado, if you want to add as a 'friend'.
I'm currently about 7000th place, got caught in a couple of lulls, plus the time lost rounding the mark off Brazil.
I'll see if I can figure out how to add you as a friend. My friend Chris & I (Mentalfee & Lepak respectively) have been racing each other, but he's pulled way out in front of me. Bastiches...
Edit: There's also a Puget Sound group, I asked to be added to it some time ago & never heard from them, we should just make a Catalina group or something for the next leg.
Edited edit: I figured out how to add your boat, so I think I should show up as a friend now on yours.
The wind changes at 3pm PST, that's when they update to the latest weather, so pay attention around that time. Check your progress as often as you can, it's not uncommon to find yourself nearly becalmed. Play with your different sail options, I've done 90%+ of the race either on my light spinnaker or the code zero, but it's worth it to play around, sometimes you'll find a course & speed more to your liking. Stay close to the yellow course if you can, but pay attention to the wind predictions, it can be worth your while to veer off of the course if there's bigger wind around.
FWIW, my friend Chris started w/in a couple of miles of me and is now about 600 miles ahead (due to my not knowing about the mark, and he just made a lucky course change at the same time that put him on a way better track, he didn't know about the mark either).
Yeah I figured out the 3pm wind change, which is pretty easy for me to monitor from work, but it's that 3am wind change that is killing me! I've gotten up a couple mornings, but it's tough! (I'm too cheap to buy the Point of Sail controller).
I don't know anything about the polars for a Volvo Open 70, but you don't get max speed with the chute up until you're wind angle is down to 140 degrees. I'm guessing this is because it's a planing boat, but on most boats, the higher you sail, up to almost 90 degrees, the faster you go due to added apparent wind. You get max speed w/ the Code 0 at 90 degrees. This means there's sort of a 'dead zone' of speed downwind between 90 degrees and 140 degrees. This is causing a lot of sail changes right now!
There's a big nasty low pressure headed my way, trying to set up to hitch a ride across the atlantic. Should be interesting.
Gary, Hah, that's the spirit! The winds have died down around the Cape for right now, but the 12 hour projection makes for a good due east spinny run for maybe a day or two.
I notice that you've dropped back a mile or two to keep my friend Chris (MentalFee) company, that's nice of you, good luck catching me...
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by delliottg</i> <br />Gary, Hah, that's the spirit! The winds have died down around the Cape for right now, but the 12 hour projection makes for a good due east spinny run for maybe a day or two.
I notice that you've dropped back a mile or two to keep my friend Chris (MentalFee) company, that's nice of you, good luck catching me... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Actually from what I see I've closed about a mile but with your spinny up you should start pulling away soon.
Paul, I see you off my <i>starboard </i>quarter & have added you as a friend.
Maybe port & starboard mean the opposite in the UK?
I've also created a Catalina International Assn group (you're limited to 30 characters for the name) if anyone wants to join. That way we can easily see & race each other.
Paul, I've added you to the group, welcome aboard! I don't know if there's any other benefit to the groups, but at least we can always see where each other are pretty easily.
For some reason I started the race as position 32,000 (about) was doing real well, logged out then was at 62,000 (about). I didn't move on the map, all looks ok from that point. Almost seems like another server with 30K+ people showed up all of a sudden in front of me.
If it makes you feel any better, my friend Chris has gone from about 60kth place to about 20kth place in about a day, so don't worry too much about your position yet. You can still walk across the Indian Ocean on VOR boats.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Steve Blackburn</i> <br />I'm noticing that when I click on other boats that they have some sort of VMG indicator (the last icon). I can't find this on my boat.
