 Fuse size for lights
Bortiquai
Initially Posted - 01/11/2009 :  22:24:36  Show Profile
I am using a fuse panel instead of breakers. What Size fuse should I be using for lights, like the running lights, mast lights, etc. They are standard (not LED) bulbs. I think the steaming light is a Perko, the mast head is a Davis Mega light. The fuse panel came loaded with 15 AMP fuses. Should I be changing these out? It uses the ATO/ATC style fuses.
Response Posted - 01/11/2009 :  22:31:49  Show Profile
I would always replace with the same amp fuse whenever possible. If the replacement fuse blows immediately, you have a short somewhere in the circuit.
Response Posted - 01/12/2009 :  07:49:07  Show Profile
IMHO..
I think of most lamps (DC, non-led) on boats drawing about .6 amps average.
Most of the lighting circuits I've had on a boat might have at the most 10 lights on a circuit so I'd probably stay around a 6 amp fuse (.6x10=6).
I personally would not be that happy with a 15 amp fuse on a lighting circuit but it will still cut out pretty quickly if you have a short.
BUT IN GENERAL:
for me for boats, I'd rather have a 5-10 amp fuse on a lighting circuit.
It is not to difficult with the internet to find out how many amps the circuit should be drawing.
Response Posted - 01/12/2009 :  13:34:11  Show Profile
Add up the wattage of all the lamps on the circuit and divide by 12 for total amps. Get a fuse of the larger size.
Response Posted - 01/12/2009 :  13:35:18  Show Profile
next larger size
jlguthri
Response Posted - 01/20/2009 :  20:27:00  Show Profile  Visit jlguthri's Homepage
One very important thing to keep in mind is to have a very clear picture of what specifically you wish to protect.
Typically, in a fuse panel, you are interested in protecting your boat wiring system (not the actual device). If you overload your boat's wiring, you burn down the boat. Besides, if you over amp a light bulb, it will simply burn out, opening the circuit.
When you look at your boat's electronics (items worth actually protecting), you typically see a fuse for the wiring, and a inline fuse for the device (which is less).
I'm a fan of putting your protection device as close to the device or wiring you are trying to protect.
In my mind, you should have a protection device between the battery and the panel to protect the wire from the battery to the panel. You should have a protection device (fuse, breaker) for each of you branching circuits, finally, you should have another protection device for any device you deem important, or that requires protection. The closer you put the protection for the actual device to the device the better for speed of action (it takes time for fuses to blow).
In your case, a fuse for the wiring, and perhaps another fuse for the actual lighting device. If it is a simple incandescent light bulb, i'd probably not protect the light bulb. If it is some sort of solid state device, I'd probably add an additional inline fuse to protect the device and size it for the actual lighting device. This way, if you wire things properly, you can very easily find the offending device, while ensure overall protection.
<b>Don't forget to protect the boat's wiring.</b> Don't be afraid to pad for safety.
