 Lazy Jacks for the 250??
ssteakley
Initially Posted - 09/25/2002 :  14:27:19  Show Profile
Is it worth it to install Lazy jacks onthe 250? There is another 250 at the other marina and I noticed it had lazy jacks. I checked on the cost and the system is not cheap so I was wondering if they are worht if?
Steve Steakley
"Moon Chaser"#385 WK
andy
Response Posted - 09/25/2002 :  18:10:14  Show Profile  Visit andy's Homepage
Steve: Absolutely! I believe there is a safety factor as well. They allow you to keep the sail under control if you have to dump it in a blow and keep the boom from falling into the cockpit or on your head. They also make it easy to flake the sail to each side of the boom when you lower it. I don't know how much they are, (my boat had 'em when I bought it) but the concept is so simple it's easy to fabricate your own. Just use the other boat in the marina as a pattern.
Andy Anderson
CSCO Kid 250WB #163
MHYC, McCall, Idaho
coldducks
Response Posted - 09/26/2002 :  09:46:53  Show Profile
we dont have lazy jacks. but we do have the dutchman flaking system. either one lets you drop the sail with out any problems and folds it as it falls. well worth the cost.
COLDDUCKS
FANTASY #409 C250WK
Response Posted - 09/26/2002 :  10:02:57  Show Profile
If deciding that the lazy jacks are not the right choice.... there are are some alternatives to sail management and the use of conventional sail ties. Choices will be influenced somewhat on how much effort is made to manage things from the cockpit.
My suggestion will likely be more toward the trailer sailor who wants to keep it simple and/or those who don't mind going onto the coach roof.
Topping lifts are a bit of a pain at first... the forgetting factor making return trips to wherever it is controled. One solution is a double ended lift with control on the starboard side of boom opposite to outhaul and the other on port side of boom aft for access from the cockpit. I have mine at the present....only on the starboard side of the boom which is very convenient as all controls are at the same location. But, I've forgotten to release the topping lift after a reef and had to return. The good news here... is that after some time... engaging and releasing the topping lift becomes routine.
A real pain however, is having to hunt sail ties...bite them in the teeth.... and communicate with crew while biting them. The answer for me...was to convert to self storing sail ties. They are rigged using bungee, two cheek blocks, one eye strap and two hammock hooks. Basically, the two cheek blocks are on each end of the boom on port side with beckets toward each other, with the eye strap half way. The bungee routes from the becket of A...around B's sheave...back to the A's sheave... and finishes at B's becket.... for three runs of bungee all of which feed thru the center eye strap.
On the starboard bottom edge....two hammock hooks are located one each half way between a cheek block and the eye strap. The bungee then rest against the boom port side....has length to be pulled over the sail and hooked to the hammock hooks. It thus makes four crosses of the sail.... and secures it very well.
And, once again, all my controls are on the starboard side ..the halyard, topping lift, both reefs and hammock hooks for the sail ties.
While on the subject of sail management... I sometimes wonder how many sailors who run lines aft on the c250 are happy with the ability to furl from the cockpit only. I find the single line system for the first reef point to need coaxing at the mast to bring the clew down well. Bill has suggested this is helped by repositioning the port mast sheave lower than original. There are just too many points at which the line engages sheaves, grommets etc. The additions of a turning block, and deck router would only add to this.
My point is... I know that its not difficult to draw the sail down.... but to get the clew drawn back well to flatten the bottom of the sail seems to me impossible to do by hauling the reef line at the end of its routing. And, hauling at the mid point, requires going to front of mast to access the port side of mast...and holding the clew taught while drawing the slack from the end... doesn't work well. I determined during this summers cruise to do away with the single line reef and opt for a two line.... my second reef is two line and a piece of cake. Will probably add a turning block at the vang eye...and bring the line back up to one of the the starboard horn cleats....again...keeping lines to starboard.
Steve, I know this went well beyond the scope of your question...but thought it might be of help to some.
Arlyn C-250 W/B #224
Edited by - Arlyn Stewart on 09/26/2002 10:04:35
bdehuff
Response Posted - 09/26/2002 :  22:44:14  Show Profile
Sailnet has a special on their "Easy Douse" lazy jack system. It comes with a sail cover permanently installed on top of the boom, which the mainsail drops into and is zippered at the top. I installed this system on my C250 a couple weeks ago. Works great. Beneteau uses a similar system on many of their boats which do not have in-mast furling.
B. Dehuff
Hull #427
Douglas
Response Posted - 09/27/2002 :  19:26:32  Show Profile  Visit Douglas's Homepage
Why not make your own. All your doing by purchasing a kit is giving someone else your money for making up a kit. Simple lazy jack system can be made for as low as 15 to 20 dollars. I made my set and its very easy.
Doug&Ruth
Boatless in Seattle
Tacoma Wa.
arlingva
Response Posted - 09/28/2002 :  11:07:48  Show Profile
Arlyn,
I would love to see a picture. I don't have any problem reefing. I just put on winch and grind.
Barb do you have a link to a web site.
Thanks, Bill C-250 wk, #614, still unnamed
Bill Swanson
C250WK #614
Steve Raffel
Response Posted - 09/29/2002 :  21:47:50  Show Profile
We had a Dutchman installed when we bought the boat. It is excellent. It is simple and gives very good control of the main especially when you have to reef under adverse conditions.
Steve Raffel
C 250 WK #408
Ben - FL
Response Posted - 10/01/2002 :  20:59:32  Show Profile  Visit Ben - FL's Homepage
Before you spend any money, you need to check out the [url="http://images.sailnet.com/dutchman/sailflaking/sfindex.htm"]Dutchman system.[/url] It's very impressive. I don't have one (yet) but did see one on Tray's "Weeny Bean".
Safe voyages,
Ben, FL s/v Chick-a-pea C250wk
cathluk
Response Posted - 10/02/2002 :  08:26:38  Show Profile
Any idea how much a Dutchman system would cost for a boat our size?
Cathy
"Blown Away"
'97 C250WK #253
mday
Response Posted - 10/02/2002 :  19:56:20  Show Profile
I was out sailing one of those Beneteaus Blair mentioned with the lazy jack system. We got hit with a fast moving squall and before we could douse the main, it got tangled up in the lazy jack rigging. This made for some tense moments trying to get the boat under control with the main half up in very strong winds. A brave crew member went forward in the storm to pull the main down by hand.
Generally, I liked the system and it was very convenient under normal sailing conditions. Just be aware that it may cause some inconvenience at times when you least need it. This system also had a fair amount of canvas on the boom which can act like a small sail and push you around when there's a strong wind.
Max Day
C250 WB 380
Lake Pleasant, AZ
