I'm replacing both my gudgeons and pintles. I have gotten the new ones from Catalina Direct. The new pintles do not line up with the existing holes on the rudder. So I am planning on filling in the old holes and drilling new ones. What is the best filler to use, and should I drill the new holes in line with or offset from the existing holes? Thanks.
Are you sure they sent you the right ones? I think that would be the place I'd start. Nevertheless, the correct material would be thickened epoxy. You first wet the inside of the hole with un-thickened and let that soak into the core. Then fill the hole with thickened epoxy. After you drill the new holes, you night want to drill the holes oversize and fill those with thickened epoxy and then drill the correct size hole. That ensures the core is sealed from water. A lot of people talk about Marine TeX, but I've never used it. I mix my own. Having said that, it could be expensive to buy epoxy for only two or four holes. Take it to the local marina and see if they will fill the holes for you. If you're anywhere near Michigan, bring it over and I'll do it for you.
Definitely treat the new holes just like the old ones. Over-drill by one bit size and remove a little core then coat with flowable epoxy (slow cure epoxy adhesive is adequate if not optimal), then fill it with thickened epoxy while the surface is slightly tacky. Re-drill the correct size hole when cured. The entire flat surface of the pintle is the load bearing surface, not the screw, so you can drill inline unless the holes are so close that that you must drill through the edge of an older hole. The new epoxy will be much harder than the old core and polyester/glass casing, making it very difficult to control the bit in an overlapping hole.
Thank you for the replies. Can you please tell me how I can recognize "flowable" and "thickened" epoxy? West Marine seems to have a bewildering variety of epoxies.
Thickened epoxy is generally made with addition of additives/fillers to the epoxy mixture to firm up the mixture. The more filers, the thicker the epoxy mixture.
The trickiest part for me was getting the holes to match up to the pintle holes on both sides. I was concerned that if I just drilled in from one side, I would "miss" the location of the hole on the other side by a small amount (at least). My approach was:
1. With a very small bit, drill half-way through from one side, and then from the other.
2. If the two holes missed in the middle (which they did), placing a bit in each hole, I could see the direction in which they missed.
3. I then re-drilled with a larger bit (but not the final size), half-way through from each side again, trying to correct for the error in step 1. This time, the holes met close to perfectly, but probably not quite.
4. Finally, using a bit that was almost but not quite the size of the bolts, I put the pintle in place and drilled in from both sides and then all the way through from one side, and with the bit coming out through the pintle holes on the other side, reamed the hole a little to size it properly for the bolt.
It was a bit tedious, but good luck with trying to hit it just right the first time through!
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">West Marine seems to have a bewildering variety of epoxies.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> <font size="2"> That is why I suggested seeing if the local marina would fill the holes for you. You would need to buy the epoxy, and then a hardener, and then thickeners, usually fumed silica, aka Cabosil or Aerosil. West sells additives in those cans and they have their own blends I just can't figure out. Mix up epoxy with hardener and that is flow-able epoxy. It's thick like maple syrup. That soaks into the wood core. Then you mix the remainder of the epoxy with fumed silica which increases the viscosity until it is like mashed potatoes. Pack that in the hole and let it cure. This is the common practice for holes that see a lot of water. The rudder, however will probably shed water as fast as it gets wet. I would almost be tempted to just fill the old holes with Marine Tex. Caulk the new holes real well and call it good.</font id="size2">
John, Dave's suggestion solutions are based on actual experience which is why the Forum is so valuable. You could also use two drill motors so you wouldn't have to rechuck. A small hole is easier to fix.
Mike; When I added my third gudgeon/pintle I bought my parts from CD and like yours, the holes did not line up with those from the old pintle. Physically, the pintle was exactly the same, pin length and diameter, size of strap, etc. But the holes were just drilled in a different location on the strap. Just fill the old holes in the rudder and re-drill. Also, like stated above, you make your own thickened epoxy. WM sells several different types of fillers, (I just bought some two weeks ago)and the colloidal silica, #406(also known as fumed silica or Cabosil), was probably the least expensive. But be very careful when using this product. It weighs almost nothing and will fly around if you stir it to aggressively. Add it to the epoxy a little at a time and mix it in gently. And with this filler you must absolutely wear a dust mask when opening and mixing this stuff. It is very hard on your lungs if inhaled (silicosis). Once it is mixed in to the epoxy it is safe. The hole drilling technique mentioned above is a good one. That's the same thing I did on mine.
Beckson is the better brand, I am not much for economy products on a boat. The beauty of Beckson is the availability of replacement parts forever and from anyone. I reused the existing backing for the upper on both my 82 and 89 so I did not cut a hole, I never had an issue in a lot of wind; but I never had heavy seas, only lake chop.
A little tip...When you replace the upper Gudgeon, take a piece or headboard or other 1/8" plastic and cut it to match the gudgeon. Place it behind the gudgeon to push the rudder just that much more up under the boat. Helps to relieve weather helm.
...that or a balanced rudder. But I don't see how that balances the original (pre-1989) rudder--all of its surface is still aft of the turning axis (the line through the pintles). You're just tilting the axis.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Headhunter</i> <br />A little tip...When you replace the upper Gudgeon, take a piece or headboard or other 1/8" plastic and cut it to match the gudgeon. Place it behind the gudgeon to push the rudder just that much more up under the boat. Helps to relieve weather helm.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Sounds like a catamaran trimming trick. We trim out weather helm on Hobies by trimming the angle of attack of the rudders.
Tilting the axis moves the bottom and CR forward. Even if he CR is still aft of the pintles, moving it forward and in conjunction with the added downward component of the drag it should make a slight difference. It might be noticeable or it might be voodoo, I don't know. I do believe that much of our weather helm is is related more to the fullness in the bows rather than CE/CR. When you are heeled, the the greater the asymmetry in the windward and leeward arcs gives the fuller leeward bow more power to turn you into the wind.
(Another winter-doldrums hijack... ) Must be voodoo. (?) Moving the CLR forward in any way <i>increases</i> weather helm, but I doubt it would be detectable in this case. You can balance a pivoting (e.g. beaching) rudder by pivoting it slightly forward of the pintles--Arlyn Stewart has done that on his C-250. That doesn't really reduce weather-helm--you still steer the same number of degrees to leeward, but with less effort--sorta like power steering.
