I have water coming into the V-berth area (not from the vent because the cushions are dry); the water accumulates underneath where the through-hull sits. I filled the anchor locker with water, as it drains through the tube in the bow I also see a trickle running down on the inside. Seems to be coming from the drainage tube. How do I best addresss /repair this problem?
That is common, I followed others advise and went to a hardware store and bought a 1" brass threaded nipple. I used a 1" hole saw to drill the new hole and two part epoxy putty to seal the drain on the inside. I used a little WD40 as lube while the nipple threaded itself into the hull, I had to back it out multiple times to relube before I got it completely through. When I was done I trimmed the excess off the outside with a hacksaw.
They say size doesn't matter. I found that the cut out for the bow lights was location of the leaks. Remove and reseal can maybe solve most of the problem.
The reason for the larger drain is that many feel the original drain is too small and too easily clogged. The 1" drain really makes the anchor locker work better.
I had some water entering the cabin and learned that when the tube was blocked in the anchor locker it caused water to back up into the cabin.
I make it a practice to clean the tube before I sail by inserting a small wooden dowel that I keep in the anchor locker. By doing so, I prevent water entering the cabin. The larger tube does make for a better upgrade solution.
