 Buying a Single Shroud
hinmo
Initially Posted - 03/09/2009 :  05:39:59  Show Profile
Is there anywhere to buy a single shroud? I want to replace one that is bent slightly on the threaded portion, preventing the turnbuckle from further adjustments. I don't feel like replacing the entire set of shrouds like the kit on Catalina Direct.
Any sources/prices?
thanks
"Kukla" '83 FK,SR
Response Posted - 03/09/2009 :  06:38:48  Show Profile
My Catalina dealer in Cincinnati fabricated them on order. I bent and bought two, and stressed them hard, and they never failed. If you order one from him, he'll want you to send the bent one to him, so he can be sure it's a stock length. I thought his price was reasonable, especially since I didn't have to buy a whole set. You can contact him at the following website.
http://strictlysailinc.com/
Response Posted - 03/09/2009 :  10:00:16  Show Profile
I seem to recall that when I bought a full set from CD, there was the option to buy any part of it... I'd call them. For another alternative, go to any major marina talk to a rigger. The guy I used did it regularly, but he said he recommended I take advantage of CD's price for the set. (How old are yours?)
Edited by - Dave Bristle on 03/09/2009 10:01:18
crcalhoon
Response Posted - 03/09/2009 :  13:51:32  Show Profile
I sent my starboard upper shroud to West Marine's rigging shop and they made a perfect fit for around $85.00 I think, three years ago.
Happy D
Response Posted - 03/09/2009 :  14:25:55  Show Profile
I ordered shrouds for my little boat. I had them custom made at [url="http://www.defender.com/html/standing_rigging.html"]Defender[/url]. They did an excellent job.
they told me two weeks delivery and I had them in two days.
hinmo
Response Posted - 03/09/2009 :  17:29:01  Show Profile
how much for one?
Happy D
Response Posted - 03/09/2009 :  19:39:29  Show Profile
The shrouds I ordered for my small boat were 1/8" wire, fork swedged on one end and an eye at the other. 13' long, two each, including shipping, $85.00.
If you fill out the [url="http://www.defender.com/html/standing_rigging.html"]request form[/url], they will email you a quote in about 1 day.
You might try the factory. I bought my keel cable from them and they were way cheaper than everybody else.
818-884-7700. Ask for parts.
Edited by - Happy D on 03/09/2009 19:42:11
hinmo
Response Posted - 03/09/2009 :  19:46:02  Show Profile
thx folks - quite doable.
The mast is up, how do I disconnect from the mast?
Response Posted - 03/09/2009 :  20:21:21  Show Profile
check online for Rigging Only
hinmo
Response Posted - 03/10/2009 :  06:25:58  Show Profile
Hows the shroud attach to the mast? (ps - boat is an hour away from my house). The ones I see online (Cat-direct) have a loop in them. Just wondering if I can use a small ladder to get to the connection while shes on-the-hard.
Anybody got a pic?
thx
sweetcraft
Response Posted - 03/11/2009 :  09:37:00  Show Profile
Dave suggested to check how old is the rig. Lower the mast? Check the Forum for suggestions to lower mast to check fittings, pins and keepers. Get four people to hold the ladder.
Response Posted - 03/11/2009 :  10:19:15  Show Profile
"anybody got a pic?"
... a few
http://gallery.mac.com/fhopper#gallery
hinmo
Response Posted - 03/11/2009 :  19:05:15  Show Profile
thanks - still don't see the connection of the shroud to the mast. Not a biggie. I'll bring a full set of tools and a ladder and WD40 and see what I can see!
Happy D
Response Posted - 03/11/2009 :  21:08:19  Show Profile
The top of the shroud has an eye
that fits between two tangs bolted to the side of the mast.
There is a clevis pin through the tangs and the shroud's eye.
A cotter pin stops the clevis pin from falling out.
Response Posted - 03/11/2009 :  21:16:10  Show Profile
Good job, Hap! I was about to try to describe that without the pictures...
hinmo
Response Posted - 03/12/2009 :  02:44:34  Show Profile
Sweet - thanks so much (gotta remember the needle-nose!)
Happy D
Response Posted - 03/12/2009 :  09:34:52  Show Profile
John,
You're going to have to unhook the shroud from the spreader somehow. Or remove the spreader from the mast and lower it all.
Use the jib halyard from the top of the mast to the lifeline stancion in place of the shroud. It doesn't have to be tight, just enough to stabilize the mast. Loosen the shrouds on both sides evenly.
I wouldn't attempt it without lowering the mast.
hinmo
Response Posted - 03/13/2009 :  03:53:19  Show Profile
Dan - I am talking about the <u>lower </u>shroud that attaches to the mast under the spreader (not the upper shown in your post above). I probably have not been making myself clear.
Thanks for the info.
Edited by - hinmo on 03/13/2009 04:22:19
Response Posted - 03/13/2009 :  10:28:28  Show Profile
Sorry, John--gotta ask one more time... How old is your standing rigging? In salt water and on Buzzard's Bay, I wouldn't want older than 15 years. The main failure points are just inside the swages, where you can't see what is called "crevice corrosion" in the cable. A rigger once told me that if you wait till you see meat-hooks, your mast is coming down.
hinmo
Response Posted - 03/13/2009 :  16:50:47  Show Profile
Yeh Dave - I hear ya, but we're going to try to get by on a shoestring budget with this rig for a while. I have to prove to myself and family that we really want to sail. If if works out ok this year (we'll take it easy on the boat) then we'll start basic upgrades next season.
I will give all the rigging a much thorough inspection B4 venturing anywhere. Thanks
Edited by - hinmo on 03/14/2009 02:03:48
