 head sail measurements
lebnene
Initially Posted - 03/23/2009 :  12:32:10  Show Profile
Does anyone know off hand what are the minimum and maximum measurements for a head sail for Catalina 250? Thanks in advance!
C250 WK
Response Posted - 03/23/2009 :  13:58:57  Show Profile
The luff measurement depends on the furler to some extent. I think mine, with a CDI furler, allows for a luff of 27'8". -- at least that's the number that is stuck in my head. The rest of the headsail dimensions are highly variable. The typical sail is a 110% jib and that figure is based on a measurement made on a line that is perpendicular to the luff of the headsail that extends to the clew. That measurement is expressed as a percentage the distance from the bow of the boat to the mast at the deck known as the "J" measurement. Since "J" on a C250 is a fixed distance of 9', a 110% jib would have a luff perpendicular (LP) of 9.9 feet. A 135% genoa would have an LP of 12.15ft, a 150% would have an LP of 13.5ft. The luff remains constant.
There are also other variables that could effect the leech such as a "deck sweeper" or a higher clew.
Then there are other headsails such as a symmetrical or asymmetrical spinnaker.
lebnene
Response Posted - 03/24/2009 :  11:27:17  Show Profile
<br />The luff measurement depends on the furler to some extent. I think mine, with a CDI furler, allows for a luff of 27'8". -- at least that's the number that is stuck in my head. The rest of the headsail dimensions are highly variable. The typical sail is a 110% jib and that figure is based on a measurement made on a line that is perpendicular to the luff of the headsail that extends to the clew. That measurement is expressed as a percentage the distance from the bow of the boat to the mast at the deck known as the "J" measurement. Since "J" on a C250 is a fixed distance of 9', a 110% jib would have a luff perpendicular (LP) of 9.9 feet. A 135% genoa would have an LP of 12.15ft, a 150% would have an LP of 13.5ft. The luff remains constant.
Thanks... I am looking for the luff then :)
Response Posted - 03/24/2009 :  12:19:33  Show Profile
According to the C250 manual, the "I" dimension is 29 ft., so your maximum luff length will be a bit shorter, say 28'6" or 8". With a furler, subtract another foot, and that gets you to john's 27'8" number.
The Sail Warehouse lists their C250 135 furling genoa luff at 28.18'. hope that helps.
