 Two-speed winches
Initially Posted - 10/19/2002 :  17:57:14  Show Profile
Has anyone upgraded to 2-speed winches on their Catalina 25?
If so, what brand and size did you purchase. Are they adequate, underadequate or overkill?
Response Posted - 10/20/2002 :  09:09:40  Show Profile
I bought 2-speed Lewmar winches as an option when I bought my boat new. I don’t remember the size, and my boat is stored 50+ miles away for the winter, but the factory could tell you what size they installed. The size they used is just right for the boat. No matter which way you crank the winch handle, it pulls in the jibsheet. If you crank it one way, it pulls the sheet in fast, and the other way pulls it in slow, but with more mechanical advantage. I keep a cheap $12.00 winch handle in each cockpit pocket (beneath each winch), so that I never have to hunt for a winch handle, or transfer it from one side to the other after tacking. I could get along without them, but like them very much.
Response Posted - 10/20/2002 :  11:59:17  Show Profile
I also upgraded to 2-speed Lewmars (and, like Steve, I don't know the size) - I bought the pair from a fellow racer for $150.00 (and then sold my original Lewmars to a C22 owner for $100.00). Especially in high winds they are a godsend and also help greatly when single-handing. If you intend to do any racing don't buy self-tailers.
Incidentally, with the larger winches I had to put 2 plastic risers under the cam cleats to get a fairlead from the winch.
Derek
Douglas
Response Posted - 10/20/2002 :  12:18:47  Show Profile  Visit Douglas's Homepage
I had 2 one speed and 2 two speeds on Wind Lass. Unless I was in very heavy air I never used them. Nice toy though,
Doug&Ruth
Boatless in Seattle
Tacoma Wa.
osmepneo
Response Posted - 10/20/2002 :  15:11:45  Show Profile
osmepneo came with 2 - 2 speed winches for the jib. Lewmar, i have no idea of size.
Don Peet
c25, 1665, osmepneo, sr/wk
Response Posted - 10/20/2002 :  15:16:23  Show Profile
<font color=blue>we use the floating handles</font id=blue>
<font color=blue>ditto</font id=blue>
Response Posted - 10/20/2002 :  15:22:18  Show Profile
<font color=blue>You're killing me here Derek! Anymmore deals like that at Canyon Lake?</font id=blue>
<font color=blue>Exactly</font id=blue>
Ellis Bloomfield
Response Posted - 10/20/2002 :  22:23:52  Show Profile
I discovered something this summer which I'm sure many do but I haven't seen it mentioned in a post. I singlehanded most of the season and found that I could handle the jib lines much faster by throwing a single or double loop around the winch, pulling it in as I moved to the other side of the boat and then just wrapping it around the cleat and sinching it in by hand. If you pull back in the center of the sheet and then take up the slack in the wrap around the cleat (there is a name for this but I don't recall it) you can actually get more tension than with a winch, and accomplish the whole thing in less time than it takes to grab the winch handle. The winch rachet serves to hold the line while you sinch it in. I don't tie the line to the cleat, just wrap it a time or two around it and this and the tension on the opposite winch hold fine. I use the same technique when I've got a non-crew guest on board. It probably doesn't look very professonal but it sure is smooth. I use a handle to raise the jib and then put it down in the cabin.
Response Posted - 10/21/2002 :  10:23:52  Show Profile  Visit Leon Sisson's Homepage
Ellis,<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>... handle the jib line [sheets] much faster by throwing a single or double loop around the winch, pulling it in as I moved to the other side of the boat and then just wrapping it around the cleat and sinching it in by hand. If you pull back in the center of the sheet and then take up the slack in the wrap ...<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>I have used a very similar technique which I believe is called "cross sheeting". I put the usual number of turns on the leeward winch, and then lead the tail to the windward winch where I also put on the appropriate number of turns. By tugging aft on the middle of the line between the winches, and then taking up the resulting slack by tailing the windward winch, I'm able to get quite a bit of tension on the jib sheet without having to move my weight "down" to the leeward side of the cockpit or use a winch handle. If I hold the (windward) tail in the same hand that is doing the tugging ("sweating"?), I can still steer with the other hand.
LeighMarie
Response Posted - 10/21/2002 :  15:13:43  Show Profile
I'm amazed you guys don't know the size of your winches. (Sounds kind of funny, though, doesn't it?) Anyway, the Leigh-Marie came with a single speed Lewmar 7 on the mast for the jib, and two double speed Lewmar 16's for the jibsheets. I did put on cam cleats with a 1" riser just aft of the the jibsheet winches, and for single handling it, the cam cleats are just the ticket! My winches are not self-tailing, and I came close to replacing them this past Spring, until I found out the price of new ones. It was somewhere around $450 each! I have to say, my old winches did just great this year, and despite my continual desire to have new things, the cost of $900 for new winches is even too much for me. I don't sail much in heavy air (yet!) and it was even rare when I had to break out the winch handles.
Dave & Sharon on "Leigh-Marie"
Hull #5128
Brooke Willson
Response Posted - 10/21/2002 :  16:10:30  Show Profile
"Even Chance" has Lewmar 16s as primary winches, but they are one speed. I didn't know there were two-speed L 16s. At any rate, I find it much easier and faster to pull the sheet in by hand until snug, and then grind to the proper trim. I also suspect it's hundreds of dollars cheaper.
Brooke
Response Posted - 10/21/2002 :  17:09:23  Show Profile  Visit aeckhart's Homepage
Brooke
Brooke, I wanted to replce my 2-spd 16's with 2-spd self-tailers nut Lewmar no-longer makes them.
Al
