 wood refinish
Page: of 3
olympia marie
Initially Posted - 08/27/2009 :  16:13:45  Show Profile
I have a '77 catalina 25. I would like to refinish the wood on the outside. Does anybody have any suggestions? I am just not sure about the teak wood. Some sites say you can sand it down and use polyurathane, then others say just to use teak oil. I need some advice.
seabreeze
Response Posted - 08/27/2009 :  16:31:29  Show Profile
I found that polyurethane will peel off with the sun. Teak oil is the best, and you can get it cheaper at Ace hardware than the marine stores. You can do several coats, and also clean before applying if needed.
Response Posted - 08/27/2009 :  17:22:31  Show Profile
Every times this comes up Cetol is in the discussion. Do a search on "Cetol" in the general and C25 forums and you will see a lot of different options and opinions. Be prepared to be reading for a long time though. This is one of the more discussed topics in this forum.
Deric
Response Posted - 08/27/2009 :  17:57:58  Show Profile
Joe,
You are correct, this topic is popular, and recurring. It almost prompts one to think about having a link on the website dedicated to the topic in and of itself.
Lot's of information in the threads here. Performing a search would be best way to research.
Good luck,
Deric
Tom Gauntt
Response Posted - 08/27/2009 :  21:26:25  Show Profile
Do all the research you want, and then go buy a quart of Cetol.
Response Posted - 08/28/2009 :  03:31:29  Show Profile  Visit OLarryR's Homepage
I use Cetol and it works very well for me. I just wash/scrub the wood and then put two coats on. That lasts about 6 months and then I repeat the process. Cetol is like a very light varnish. It is easy to work with, perhaps not as strong adhering as a varnish but believe it is easier for keeping up the maintenance on it and it lasts at least a season or longer. But I also keep my boat in the water all year and the Cetol works well under those conditions with little attention to it.
Teak oil is in my opinion best. It has the nicest and natural look to it. But my experience with it eons ago was that you have to be prepared to attend to it at least in mid-season or perhaps twice during the season, otherwise, teak oil starts to wither, wood turns grey and then you have to bring it back to parade-rest by bleaching it out and starting over again. If you frequently visit your boat and doing maintenance, etc is relatively easy for you time-wise, then teak oil is the way to go. I tend to mostly do maintenance during the off season and procrastinate on maintenance during the season and so that is one reason I go with Cetol as a compromise for not going with teak oil.
You can also prolong the life of whatever you treat the wood with by buying those sunbrella covers for the wood rails, etc and then covering up the wood for all times when you are not sailing. If I ever get around to going that route....then teak oil or varnish would be more palatable for me. For example, my tiller is treated with varnish and when not sailing it always has a tiller cover on it. I do not believe the PO ever revarnished the tiller and in almost the 4 years I have had the boat, I never have revarnished the tiller and it looks great !!
So....the decision on what to treat the wood has a lot to do with some other factors and how each person views them.
Response Posted - 08/28/2009 :  06:01:57  Show Profile
One thing makes teak different from just about all other woods in regard to finishing... the oil in it. That oil, when sun heats it, can cause varnish or polyurethane to lift off and crack, after which you have to remove it and refinish--a big job. Cetol is slightly permeable, and allows the teak to "breathe" a little. It's also much softer, so it tends to wear away, but you can add a coat or touch up with very little preparation.
There are now three color versions (the pigments add UV protection) plus a gloss version (with no pigment) that's meant to be a top-coat over the others. I use the original Cetol Marine with no gloss topcoat, for a satin finish--tried the new Natural Teak, but decided it was more yellow than I preferred. As always, YMMV.
fpill
Response Posted - 08/28/2009 :  06:57:41  Show Profile
I'm a Cetol fan. I used the Cetol natural this past spring, and it was easy to use. I leave the boat uncovered and the Cetol is holding up fine here in the North East. I like the look, and hopefully this winter, when I touch up any worn spots, will be the real reason I used it. I never want to remove polyurethane/varnish again. I tried using thinner, heat guns, thinner with methylene chloride(really bad for you), it was not fun. I hope this winter I'll just mask off the areas I want to touch up and have at it.
I did not Cetol the tiller last year, so I still have to strip it this winter. It will be a reminder why I switched.
I hope this helps.
P.S. I did not use the gloss overcoat.
Peregrine
Response Posted - 08/28/2009 :  07:31:50  Show Profile  Visit Peregrine's Homepage
<font face="Comic Sans MS"><font size="2"><font color="navy">Armada
Is like Cetol, I just like the color better. I use "satin" not the high gloss.
Cetol has gone a long way twards getting rid of the orange tinge but Armada is IMO much closer to a "varnish" look.
It works and lasts like Cetol.</font id="navy"></font id="size2"></font id="Comic Sans MS">
Response Posted - 08/28/2009 :  10:53:49  Show Profile  Visit aeckhart's Homepage
Whatever you settle on you have to resign yourself to periodic maintenance to keep your teak looking good. I for one would rather be putting my time on the boat sailing rather than maintaining. I haven't done it yet but have long considered replacing the teak handrails with "poly-fiber(?)-plastic rails or with stainless tubing. The plastic rails are more expensive than stainless but using stainless means plugging bore holes in the cabin roof. Still, a labor saving alternative for the long-haul.
rustynbigd
Response Posted - 08/28/2009 :  12:43:07  Show Profile
Well, I broke down and gave the Epiphane Varnish I got at West Marine a go. I put 6 coats on the companionway boards to see what it would look like and they look great. I had used Cetol previously. The work was dead hard, though. I am not a good furniture refinisher, so I really didn't know what I was doing. I sanded them down to the bare teak, then applied each coat, lightly sanding in between. It was about 95 degrees the day I was doing it so the varnish dried a tad quickly, and I also just brushed the sweat that dripped from my brow on into the coat. I plan to do the rest of the teak this fall when the cold front hits and takes us down to about 80 or so.
John Pittman
Response Posted - 08/28/2009 :  15:54:30  Show Profile
Nice, I also use Epifanes.
Its alot of work some say but I think our boats are worth it.
I applied 7 or 8 coats to the outside wood work last spring and it still looks great.
It takes alot of patience, and has to be done just so, cool weather,applied in the shade,light sanding between coats, multiple tack cloths ect.
I did learn that you need to be careful with the masking tape, dont leave it on for to many days or its hard to get off. Its temping to keep applying coats because its just gets better and better but the sun can really bake the tape on in conjunction to the varnish glueing the tape down.
P.S. though its more work I dont think anyone will argue that a quality varnish finish produces the best results!!!
Edited by - John Pittman on 08/28/2009 16:49:51
olympia marie
Response Posted - 08/28/2009 :  16:41:22  Show Profile
Thanks everybody for your advice!
Happy D
Response Posted - 08/29/2009 :  05:36:28  Show Profile
If you like Ephifanes, try Interlux's Schooner 96. I think it flows on nicer.
Use a Scotch brite to scuff the surface between coats and only sand every third coat with 220 grit.
Response Posted - 08/29/2009 :  08:36:37  Show Profile
to net it all out, I sanded the old stuff off, cleaned it with acetone, gave it 5 coats of Deks Oljies, gave it 5 coats of Sikkens Cetol (original recipe) and it turned out like this:
Companionway crib boards, cabintop endcap and handle
Only problem - I started the project in January and finished up in March
Response Posted - 08/29/2009 :  19:01:10  Show Profile  Visit delliottg's Homepage
Concur on Cetol.
michaelj
Response Posted - 08/31/2009 :  03:47:12  Show Profile
I just did this on my '81. I removed the wood from the boat, then cleaned it with TSP and a synthetic fiber bristle brush. After drying, I applied three coats of Sikkens Cetol (your choice of color) at 24 hr. intervals. It looks great! The only thing you will have a problem with is the cabin trim. The vertical pieces on my boat were glued in place and had to be done on the boat. The horizontal pieces above them have wooden plugs covering the screws which have to be drilled out. Be careful about spills; Cetol will instantly stain the fiberglass and is very hard to get out.
Even Chance
Response Posted - 08/31/2009 :  15:51:03  Show Profile
Interesting article in this month's "Good Old Boat" about Bristol Finish. I've seen it advertised, and wondered.
I used to use Armada, but went to varnish. I'm considering the Bristol Finish, given what the article says. Cetol looks to "plasticky" for me.
Response Posted - 08/31/2009 :  18:32:35  Show Profile
See the following threads...
http://catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=19829&SearchTerms=Bristol
http://catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=17561&SearchTerms=Bristol
http://catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=19208&SearchTerms=Bristol
I think you'll conclude that Frank Gloss won't be featured in Bristol Finish ads.
Response Posted - 09/01/2009 :  18:23:13  Show Profile
I put on 3 coats of Watco teak oil from Lowe's (I think Frank mentioned it when he still had a C-25) in January in Florida to cover me until I could Cetol everything, but it lasted until June when I put on 2 refresher coats. Paint it on generously, let it sit for 15 min., and wipe it off. It's incredibly easy and has proven so durable that I have forgotten about Cetol
Happy D
Response Posted - 09/02/2009 :  05:48:20  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">..... I have forgotten about Cetol<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
I couldn't agree more
Response Posted - 09/02/2009 :  06:39:19  Show Profile  Visit DaveR's Homepage
I was waiting for the oilers!!
Delilah
Response Posted - 01/09/2011 :  10:17:48  Show Profile
I just about have all of my interior teak refinished. Started over the summer taking a hand full home after our day of sailing. Varnish it over the next week or so and then bring back down and install. I am down to a couple of the bulkheads, the forward sink area and the galley counter trim.....It has been fun and looks great! I am not sure who had the right idea to stain teak with cherry coloring but I am glad to be rid of it![img]http://im1.shutterfly.com/media/47a1df28b3127ccefc471490391c00000030O00AatW7lwzbtGYPbz4M/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400//img]
Response Posted - 01/09/2011 :  10:48:15  Show Profile
Pssst--change <b>//img ]</b> to <b>[ /img ]</b> (without the spaces).
Edited by - Stinkpotter on 01/09/2011 10:48:56
Response Posted - 01/09/2011 :  11:31:47  Show Profile
It is really pretty simple, read Practical Sailor's ongoing tests, decide how much work you are willing to do to get and maintain the finish, and go. Varnish is very labor intensive in initial application, requires annual maintenance, and needs to be stripped and redone from scratch every few years, but it is the only option if your really want the gold-plater wet look. Cetol and equivalents are less labor intensive initially and a lot less work to touch up and re-coat every year or two with a different look. Oils are minimal labor initially, require nothing but a wash to re-coat, but must be reapplied from every couple of weeks to every season, depending on the product
Response Posted - 01/09/2011 :  12:23:29  Show Profile
And then there's [url="http://www.semcoteakproducts.com/semco_products.htm"]Semco[/url]... sort of a hybrid between teak oil and finishes like Cetol and Armada. The look is more like oil (or, if you prefer, weathered teak), but the weather, sun and mildew protection is apparently more like Cetol. Friends use it on their classic cutter, and I'm thinking about stripping my Cetol and going with Semco this winter--still undecided.
Edited by - Stinkpotter on 01/09/2011 12:25:05
Page: of 3 Previous Topic Topic Next Topic
