Who has recommendations on type, brand and capacity for replacing the battery on a 250? Dealer recommended traditional flooded deep cell, and indeed our nearly 8-year old original is still hanging on. Marina sells Interstate batteries for only $100. Meanwhile, WM offers gel, AGM, and all that sexy stuff, too, at a price. Only additonal electrical load planned is a Radio/CD stereo.
We use two of the WM AGMs and are very happy with them. When cruising we use a depth/speed device, GPS Chartplotter, Nav lights, VHF radio, interior lights, etc. We also have an electric start outboard. Our batteries are connected to a Charles 10 Amp charge. The nice thing about AGMs is that they are maintenance-free and can be deeply discharged without damaging the battery.
Many people use traditional flooded cells and are happy with those too. It's not one of those things where there is a right and a wrong. It depends on your use and your budget.
I have a gelcell in my airplane because I turn it upside down occasionally. My water scooter has an AGM (absorbed glass mat) because it gets a lot of vibration and shocks. My car and sailboat have the old standard flooded lead acid batteries. All do just fine if properly maintained, which means fluid level kept above the plates for the flooded cells. And using a good REGULATED trickle charger such as those sold by Battery Tender for the boat and plane batteries. In my opinion a flooded battery is all you need in a car or sailboat. To reduce the chance of spilling acid mount the battery so that the cell caps are lined up perpendicular to the boat's centerline.
If you can find a golf cart battery that's the best choice of all. Cart batteries have solid plates and are true deep cycle batteries. The "Deep Cycle Marine" batteries are a better choice than a regular car battery because the plates are composed of coarser grains. Coarser grains make the battery more resistant to damage from deep discharge events. Car batteries have fine grain plates which makes them better for high amperage engine starting duty.
Any traditional, lead acid, deep cycle, RV/marine battery will work fine. I would not get it at your marina...at least I would not get it from MY marina. Their prices are much higher than WalMart, Sams, Costco, etc.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jbkayaker</i> <br />If you can find a golf cart battery that's the best choice of all... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">...except you need a minimum of two because they're 6 volts, so they need to be paired in serial on a boat.
12 volt cart batteries are available too. And true deep cycle batteries with solid plates are a better choice if you intend to run them way down before recharging. Do that with a car starting battery a half dozen times and the life will be considerably shortened.
