 Speaker enclosures
Initially Posted - 03/12/2010 :  16:11:19  Show Profile
For all the handy woodworkers out there, instead of mounting my stereo speakers in holes cut through the cabin bulkheads down below, I'd like to build a pair speaker boxes made out of teak.
I could mount the speaker boxes almost anywhere in the boat on hangers under the window area inside the cabin, on the bulkheads or somewhere near the galley. If I found that location inconvenient or provided an unbalanced sound, I could rearrange one or both speakers.
Now, I can buy 1" x 6" or 1" x 8" solid teak, but it costs an arm and two legs, and it's kind of thick and clunky. I'd prefer 1/2" thick material.
Is any kind of teak plywood or laminate available that I could use to build the boxes? Or is it possible to slice a 1" thick boards into 1/2" thick boards on a table saw?
I want enclosures that are about 8" x 10" by 3.5" deep.
Suggestions?
Response Posted - 03/12/2010 :  16:43:11  Show Profile
Bruce, rather than go through all the trouble of making speaker enclosures wouldn't something like these work just as well? http://www.outdoorspeakerdepot.com/aphidepaspp1.html
Response Posted - 03/12/2010 :  17:39:53  Show Profile
<br />Or is it possible to slice a 1" thick boards into 1/2" thick boards on a table saw?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">A band saw would be a better tool for this . . . followed by a pass or two through a planer.
Response Posted - 03/12/2010 :  18:25:57  Show Profile
Plywoods are available with teak or a hugh variety of other woods for the face ply in both interior and marine qualities. I used birch plywood with a teak stain for a project on my last boat, and it was beautiful,
Response Posted - 03/12/2010 :  21:25:49  Show Profile
Scott, I like the prices (per pair) and the specs for the speakers, and I might consider using them in the cockpit, but I would like to retain the wood-trimmed interior in the cabin.
For instance, I created a teak enclosure/bracket for the radio, so I'd like to remain consistent with the speakers.
Dave B., so where can I get the teak veneer plywood. Last summer, a dockmate showed me a piece of 1/2" veneer plywood that I thought about for the speaker enclosures. But the guy is in FLA till May, so I'm on my own.
Response Posted - 03/12/2010 :  21:50:43  Show Profile  Visit delliottg's Homepage
If you're going to buy 1" thick teak, keep in mind, that that 1" dimension might actually be 3/4" (EG a 1x4 is actually 3/4" x 3.5"). If you then use a 1/8" thick blade on your table saw, you've now down to 5/16" thick on each side. A bandsaw is much-much better for re-sawing wood, and if you put the sawn side on the inside of your speaker enclosures, no one will ever see it.
However, as others have stated, you can simply buy teak plywood, although it might not be that easy to come by where you are. There are other options though, it's pretty simple to buy luann door skins (Philippine mahogany) which will be large enough to make several enclosures from.
To locate the plywood in your area, call some of the local hardwood shops and ask around. There are only about 2-3 places in the Seattle area that carry specialized plywood, and for two of them, you kind of have to know that they exist, they don't advertise that I'm aware of.
Edited by - delliottg on 03/12/2010 21:54:39
Response Posted - 03/12/2010 :  22:52:01  Show Profile
I don't know where you can find it in your area, but a web search for teak plywood will give many places to order it. A local search for marine plywood might might find a place that carries or can order it.
Response Posted - 03/13/2010 :  10:42:26  Show Profile
Your marina undoubtedly knows of carpenters who work on boats, and carpenters who work on boats know where the wood is. The only question is whether they'll tell <i>you!</i>
Luan ply should work for you--it's cheap, and from the same general family of trees, although it might be harder to work for furniture-grade joinery. If you can't find "teak" stain, try a mix of something like cherry and golden oak, and test it on the luan.
Edited by - Dave Bristle on 03/13/2010 10:44:31
Response Posted - 03/14/2010 :  08:41:09  Show Profile
<br />. . . Luan ply should work for you--it's cheap, and from the same general family of trees . . .
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">As nice of grain Luan has (a thin veneer of mahogany,) I would have never thought to use it for anything where a high finish was desired (I've always used it for underlayment.) Then a friend applied it as veneer for parts of the interior of a 28' sailboat he is building. After applying a teak colored stain, the color and grain are gorgeous and after 7 coats of polyurethane it looks absolutely outstanding.
As my father used to day, "Whoda thunk it?"
Edited by - OJ on 03/16/2010 04:54:43
Response Posted - 03/14/2010 :  19:39:19  Show Profile
Dave - I don't have a bandsaw, only a tablesaw
I did locate a small scrap of what looks like Luan with a teak veneer on it as OJ described.
I have found a lumber store locally who may have it, or may be able to order it.
The trick is to get the joint right with plywood, but I could use a 3/4 round trim piece and use a router to cut an inside corner to cover the unfinished edge.
For the interior, I plan to use teak oil or Deks Olje on the teak.
Dave B - it's funny you should mention mixing stains - I've done so with pretty good success in the past except for one thing: It's <i>very, very</i> difficult to repeat a mixture for the next time you need to match the combo.
Response Posted - 03/14/2010 :  20:19:48  Show Profile  Visit Leon Sisson's Homepage
Get with the guy parting out a C25, and have him rough cut his original teak faced 1/2"plywood bulkheads down for shipping to sizes you can work from.
Response Posted - 03/15/2010 :  20:18:14  Show Profile
<br />I did locate a small scrap of what looks like Luan with a teak veneer on it as OJ described.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Luan <i>is</i> the veneer--it's a mahogany. Home Dopey (among others) has luan-veneered plywood.
Response Posted - 03/19/2010 :  17:35:24  Show Profile
Dave, I've used Luan plywood for floor underlayment projects because of its stiffness.
I've never thought about using it for cosmetic purposes
JimB517
Response Posted - 03/20/2010 :  09:40:40  Show Profile  Visit JimB517's Homepage
I made mine out of particle board in an afternoon, and painted them. The speakers are old cockpit speakers. I made my own cover out of a nice wool piece I picked up at Jo Ann fabric for $0.50. I put eye bolts in the speakers and eye bolts in the bulkhead. I use a wire tie to secure the speaker to the bulkhead (wire tie through the eye bolts). They sit on the foam cushions, and don't move when the boat heels, yet are easily removable.
Sounds great. Now you probably want something to look nicer, and that is fine, but if you put them on the bulkheads, make sure they won't move and make them removable.
Oh the stereo is an old car cassette player that has been put in a waterproof box and is in the quarterberth. I play an iPod through it with a casette adaptor. It's been in there about 15 years. It goes to show that you don't need to pay extra for a "marinized" version.
Response Posted - 03/21/2010 :  19:24:07  Show Profile
Jim,
I like the way you think. I am taking a slightly different tack, but am making the audio system semi-permanent: radio, speakers, power and Ipod/XM slide in and plug in. And just as easily, unplug and slide out.
I posted my approach in the audiophile topic on the general forum.
Once complete, I plan to post some photos.
