 Replace Forward Hatch
Bay Tripper
Initially Posted - 03/21/2010 :  13:41:26  Show Profile
Has anyone replaced their forward hatch with a Acrylic lens in an alum frame? If you did what manufacturer and model did you use?
Dick Mosteller
Christiana, PA
Bay Tripper--250 WB 1995 #128
Response Posted - 03/21/2010 :  18:08:24  Show Profile
Dick, I have not done this but if you figure out the part that does it please post the results. This would be a great mod to let even more light into the cabin.
Response Posted - 03/21/2010 :  18:26:27  Show Profile  Visit delliottg's Homepage
Yep, I'd be very interested as well.
Russ.Johnson
Commodore
Response Posted - 03/25/2010 :  02:56:14  Show Profile
Dick,
I believe the C250 2008 Model changed the forward hatch to acrylic.
You can see pictures on the Catalina website.
http://www.catalinayachts.com/yachts.cfm?act=model&id=16
You might contact either Catalina Yachts or Catalina Direct about the manufacturer and model.
Russ C250 #793
Bay Tripper
Response Posted - 03/29/2010 :  16:17:31  Show Profile
I just sent Catalina an e-mail requesting weather the new hatch will fit on the older boats. I let you know as soon as I get a reply.
Bay Tripper
Response Posted - 03/29/2010 :  17:23:19  Show Profile
Here is Catalina's reply
Richard,
Below is the info on the hatch that we have used here in California on the C 22. I am not certain if it is the same hatch they are using on the C 250 MKII but I have cc'd Warren to see if he can confirm it. There are many different size hatches available. I am sure that one of them will work for you application.
Good Sailing,
Part # G995-1100
Hatch opening -- 19 1/4" X 19 1/4 (489 mm X 489 mm)
Hole Cut Out -- 19 3/4" X 19 3/4" (501 mm X 501 mm)
O.D. Of Deck Flange -- 21 7/8" X 21 7/8" (556 mm X 556 mm)
O.D. Of Lid -- 22 1/6" X 22 5/16" (560 mm X 567 mm)
Cutout Radius -- 1 11/16" (43 mm)
Weight -- 9.75 lbs
Color -- BLACK
Kent Nelson
Engineering Department
Catalina Yachts
21200 Victory Blvd.
Woodland Hills, CA 91367
(818) 884-7700 ext. 237
(818) 884-3810 Fax
kent@catalinayachts.com
MartinJW
Response Posted - 04/03/2010 :  08:49:24  Show Profile
We have the tinted, acrylic hatch up front, and we really like it.
The manufacturer is BOMAR, and I'll see if I can find a manufacturer's part number next time I'm visiting the boat.
