 Who makes good LED trailer lights?
Initially Posted - 09/12/2010 :  21:13:30  Show Profile  Visit delliottg's Homepage
I discovered today that my "new" LED trailer lights are full of water which explains why I've been having problems with them. They're remarkably good at holding water in, so much so that they look normal.
I ran all new wiring today thinking that was my problem because there was some corrosion going on at the connections. When I got to the lights, I pulled them off and noticed the water inside, they both are leaking around the mounting studs, and the "marine" wire looks to be corroded all the way down it's length. Grrrr... This trailer has been submerged three times since I installed these lights!
Has anyone installed LED lights that have worked out well for them?
David
C-250 Mainsheet Editor
Sirius Lepak
Response Posted - 09/13/2010 :  03:09:11  Show Profile  Visit britinusa's Homepage
We installed lights from my fav store HF, but they all failed within a couple of dunks
My local NAPA store had the center light bar and the side/brake/turn lamp sets in stock, and so far no issues at all.
BTW, I cut open the HF lamp sets, figured out where the issue was (corroded cable and a one lamp bar out). Cut out the individual lamp strips that still worked. I dremelled them down to the size of a festoon lamp and they are now installed in one of my original cabin lamp fixtures (the 6" white round fixtures) and work like a charm.. all except that my power drain meter cannot detect when they are turned on!
Response Posted - 09/13/2010 :  07:24:51  Show Profile
1. Northern Tool.
2. How about the place where you take your trailer for servicing?
Response Posted - 09/13/2010 :  09:49:12  Show Profile
I put the WM kit specific to my model trailer on several years ago. One light failed about 6 months after WM announced a recall on certain part numbers. They replaced the lights and I haven't had any problems since with launch and recovery twice a year in salt and fresh water.
Response Posted - 09/14/2010 :  20:25:02  Show Profile
Do you get the Overton's catalog? Might want to check them out also.
cat25
Response Posted - 09/20/2010 :  14:09:54  Show Profile
Try dry launch lights. There not led but they are good.
Response Posted - 09/20/2010 :  15:08:35  Show Profile  Visit delliottg's Homepage
I found some [url="http://seasense.com/index.php?page=shop.product_details&flypage=shop.flypage&product_id=772&category_id=47&manufacturer_id=0&option=com_virtuemart&Itemid=26"]SeaSense lights[/url] at a local boat shop last week & installed them yesterday. I explained my problem to the salesman, and he knew exactly what I was talking about and showed my why these particular lights will (or should) solve my problem. The entire light is sealed, the carriage bolts that attach to the trailer go through plastic channels that aren't central to the light enclosure. If you crank down on them hard enough to crack them, it's just the channel that gets damaged, not the LED enclosure. The power wires go through an epoxy blob so they're unlikely to leak. I have high hopes, they seem well built.
Response Posted - 09/20/2010 :  15:29:28  Show Profile  Visit piseas's Homepage
David, looks like you found the answer but are there lights made that are magnetic? which you would remove while putting in water?
Edited by - piseas on 09/20/2010 16:01:30
Response Posted - 09/20/2010 :  16:00:17  Show Profile  Visit delliottg's Homepage
They are not magnetic, they're bolted to the trailer frame, so they'll be submerged each time I launch & recover.
Chris Z
Response Posted - 09/20/2010 :  16:57:00  Show Profile  Visit Chris Z's Homepage
I have bought a set from Walmart for my C25 trailer and my fishing trailer. I have not had a single problem. The ones on my fishing trailer go in once a week.
Stuff4Toys
Response Posted - 09/25/2010 :  17:35:33  Show Profile  Visit Stuff4Toys's Homepage
I like products from Optronics, won't find 'em at WM
Ed Cassidy
Response Posted - 09/25/2010 :  20:31:46  Show Profile
The Optronics kit I got at the local parts store had a lifetime warranty. I'm going to test it now that both taillights had failures.
Ed
Elfreda
Response Posted - 04/19/2012 :  19:15:01  Show Profile
<br />We installed lights from my fav store HF, [url=http://www.ledstrips8.com/wholesale/what-is-smd-5050-or-smd-5050-products/]smd-5050[/url] but they all failed within a couple of dunks
My local NAPA store had the center light bar and the [url=http://www.ledstrips8.com/wholesale/12-volt-led-lights-or-led-lighting-for-bulb/]12v led lighting[/url] side/brake/turn lamp sets in stock, and so far no issues at all.
BTW, I cut open the HF lamp sets, figured out where [url=http://www.ledstrips8.com/wholesale/flexible-led-strip/]led "flexible strip"[/url] the issue was (corroded cable and a one lamp bar out). Cut out the individual lamp strips that still worked. I dremelled them down to the size of a festoon lamp and they are now installed in one of my original cabin lamp fixtures (the 6" white round fixtures) and work like a charm.. all except that my power drain meter cannot detect when they are turned on!
Response Posted - 04/20/2012 :  13:25:29  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Ed Cassidy</i>
<br />. . . The Optronics kit I got at the local parts store had a lifetime warranty . . .
Ed
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Trailer-Rite installed Optronics tail lights - materials seem to be high quality - so far so good. Not sure about the side marker lights.
http://www.etrailer.com/Trailer-Lights/Optronics/STL78RB.html
Edited by - OJ on 04/29/2012 06:11:52
hewebb
Response Posted - 04/21/2012 :  05:23:42  Show Profile
Bought my water proof LED lights at Tractor Supply
Response Posted - 04/21/2012 :  06:31:27  Show Profile
I'm curious... Why LED's? They're great for conserving batteries between charges, but that conservation becomes a premium requirement to justify their cost... Now you're buying them to submerge in water (salt?) on a trailer hooked up to a running tow vehicle? I've never had trailer lights that didn't leak eventually, but I never worried too much about the cost of replacing ordinary lights now and then, and my car's alternator never struggled with their draw.
Response Posted - 04/21/2012 :  08:19:26  Show Profile
Dave,
I gotta agree with you - LED trailer lights are a solution looking for a problem. That said, I've stopped at truck stops and have found LED replacement bulbs for conventional 1156 and 1157 bulbs, but that's because truckers turn off their engines but not their lights when they sleep and need to conserve on battery power. Think anchor lights.
Response Posted - 04/21/2012 :  09:14:05  Show Profile
LED trailer lights can be completely sealed units, WM's and just about all quality ones are, eliminating any risk of internal water, corrosion, and failure. They are brighter and don't need to be unplugged when you back into cold water. Trailer lights, even those not submerged, are an ongoing problem from rain, spray, road salt and anything else that finds it's way in. It is definitely not a solution in need of a problem. I have several years on my lights and consider them a blessing. I rewired my trailer this year with dedicated ground wires and uninterrupted wire runs to all lights and expect to live happily ever after.
Response Posted - 04/21/2012 :  12:52:33  Show Profile
<br />I'm curious... Why LED's? They're great for conserving batteries between charges, but that conservation becomes a premium requirement to justify their cost... Now you're buying them to submerge in water (salt?) on a trailer hooked up to a running tow vehicle? I've never had trailer lights that didn't leak eventually, but I never worried too much about the cost of replacing ordinary lights now and then, and my car's alternator never struggled with their draw.
Because the bulbs don't fail as often from vibration while traveling down the road. How many trailers of all types have you followed on the road that had one or more lights not working. LED's are less prone to vibration failure. That's why semi rigs are going to them more and more.
In addition they are normally brighter than the old style lights.
Edited by - GaryB on 04/21/2012 12:54:09
harris
Response Posted - 04/29/2012 :  05:32:11  Show Profile
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Stinkpotter</i>
<br />I'm curious... Why [url=http://www.niceledlights.com]LED[/url]'s? They're great for conserving batteries between charges, but that conservation becomes a premium requirement to justify their cost... Now you're buying them to submerge in water (salt?) on a trailer hooked up to a running tow vehicle? I've never had trailer lights that didn't leak eventually, but I never worried too much about the cost of replacing ordinary lights now and then, and my car's alternator never struggled with their draw.
Because the bulbs don't fail as often from vibration while traveling down the road. How many trailers of all types have you followed on the road that had one or more lights not working. 's are less prone to vibration failure. That's why semi rigs are going to them more and more.
All time right here also LED Stripes, LED Lamps, LED Flashlights, LED Bulbs, and many other high quality LED products. You can try to this.
Edited by - harris on 05/07/2012 00:02:55
Frank Law
Response Posted - 04/29/2012 :  12:42:33  Show Profile
Regarding lights--- On one of my smaller boats I mounted the trailer lights on a board and just put them on when trailering and lifted them off at the ramp.. lights never got wet ..no problems
Frank Law
"ABOUT TIME"
1983 #3519
SWK , SR
