I have done a search on installing sister bolts. I have the stuff to install the studs but does anybody know the depth of drilling and tapping. Im sure the kit provides instructions but I have purchased tap and drill elsewhere. Also do you install them right next to the old studs? thanks you Don
When I did mine last summer I drilled approximately 3 to 4 inches into the cast iron. I placed 6 bolts near the older bolts (not more then 2 inches away). The problem was the drilling; that was a job. Moreover, I was disappointed by the drill that CD sent me, and ordered a different one. It is absolutely important to first drill a pilot hole. I'll try to post a picture of my setup a little later (or tomorrow). Jan
Thank you for your help Jan , I have herd that drilling a pilot hole helps alot. I heard it is pretty rough drilling into cast iron. I bought a can of some good tapping oil and a heavy duty drill.. wish me luck ...Don
What saved me was to buy some long (12") top of the line 1/4" drill bits at Lows and used them with a good smaller hand drill to drill the pilot holes. Accessibility was an issue, but the tactful placement of the holes gave me access and this did wonders after fighting on my first two two holes that I did not have access to with my smaller hand drill.
When I sistered my cast iron keel I used four studs. One inside of each of pair of the existing end studs and one on each side of the existing center studs. Part of the reason I took that approach was it was a lot of work to drill those holes and the 6 original studs were still maintaining their grip. I used 3/4" all-thread for studs which is a larger diameter than the existing studs. There is a 1" thick wooden sole you will drill through to reach the cast iron keel.
Don, Yes I did. I made sure that I let the sill/sole dry out after I drilled the initial hole through the wood (I let it dry for a few weeks actually) and then I filled the holes with penetrating epoxy. When that was dry I re-drilled the holes and went for the cast iron.
Jan Im going in with 1/2-13 stainless steel threaded rod 3/4 size sounds alot beefier stronger, good idea. So jan the wood soul was sound just needed to be aired for some time to dry?
