I cut out a plate to cover a hole in the cockpit. The plate was stainless steel. After cutting with an angle grinder, I smoothed the edges with a brass wire brush on my bench grinder.
After only a couple days I started to see rust forming around the edges. Why? How can I stop rust from forming?
Is it realy stainless. Test it with a magnet. The more the iron content the less stainless it is. I dont think you will ever find any true stainless. It all depends on quality or how it was manufactured.Stop it from rusting by painting it with a good epoxy.
I'm going to go out on a limb and speculate that you're seeing galvanic corrosion from tiny particles of the brass brush in the tiny grooves and scratches along and close to the edge. I'd suggest smoothing with a stone wheel or other non-metallic abrasive and see what happens.
Incidentally, there's stainless and then there's stainless, identified by numbers such as 316 (generally better) and 304 (generally more prone to tarnishing). Usually what you see is not the kind of rust that structurally damages the steel--it's discoloration. Stainless steel prevents rust by creating a virtually invisible oxidation coating on itself. It requires oxygen to maintain that coating. However, dissimilar metals can affect that protection--you don't want to fasten stainless with bronze screws, for example.
Oops--I hear some cracking... I'm climbing back off the limb. <img src=icon_smile_blush.gif border=0 align=middle>
West Marine sells a pen-like product - you twist one end and glass fibres protrude from the other. It's designed to clean up hard to reach rusty areas - and it works well. (Expensive little job tho'!) Derek
If you are going to heat or weld stainless you have to be sure you get the low carbon stainless. 316L and 304L are what you need to look for. You created enough heat with the grinder to cause a chemical reaction where the chromium in the stainless reacts with the carbon creating chromium carbide. The free chromium will prevent rusting but the chromium carbide will not.
