Okay, I'm taking the advice and working toward a strap launch (sounds a bit kinky)which will take place the end of this month. It's been a long winter without sailing.
In checking within our forum its been written that a spindle wheel is necessary or at least helpful for a strap launch:
<b><font color="red">Spare Tire Carrier w/Eliminator Removable Spindle/Hub</font id="red"></b> It runs about 120 bucks. Several on line stores carry it. Already have the five bolt spare wheel & tire. Check.
Besides picking up the spare tire/spindle wheel carrier what strength strap (4,000 lb?) is needed and at what length?
Bob Watson Sparkle Plenty '99 Catalina 250/WK #421 Oak Bottom Marina Whiskeytown Lake CA
The length of the tow rope depends on how steep your launch ramp is and whether you want to get your tires wet. I use two 20 foot tow ropes attached together with a shackle. Last season my rear tires barely touched water but this season with the fluctuation with our lake I had the rear bumper in the water. My advice would be to get a couple of straps. Also check that the launch ramp extends in the water as far as you plan on launching your boat, you don't want your boat and trailer to suddenly fall off a ledge at the end of the launch ramp.
Picks from last year, the harbor that these pictures were taken in is dried up,the good news is the lake is supposed to rise 20-40 feet this year.
We also use a long-travel jack that retracts far enough to allow the wheel to reach the ground.
We use a special pintle hitch to attach the strap to the tow vehicle.
We have a small trailer jack at the rear of the trailer. Sometimes the ramp is steep enough that if a person climbs up the swim ladder the trailer will tilt back. Lowering this jack prevents that.
Looks complicated but the process is really straight forward and works well. We have found the key is to make sure the trailer is aimed STRAIGHT on the ramp so it doesn't veer of to one side or the other.
• Buoys and line for slip • Fenders with hangers • Several long lines • 3 tow straps • regular hitch • Pintle hitch • Wheel chocks • Dock lines and spring line • Dock-A-Matic • Boat poles • Tool bag • Rubber mallet to pound hitches if needed • Fuel tank with fuel • Battery • Tie-down ratchet straps if needed
Launch
• Make certain outboard is ready to go including battery • Deploy fenders on boat • Back trailer to water’s edge • Unhook trailer winch strap from bow eye • Place chocks behind trailer wheels • Deploy aft port jack on trailer • Unhitch trailer • Pull vehicle forward • Lower trailer jack to set spare tire/wheel on ground • Change vehicle hitch to pintle hitch • Attach tow straps to trailer A-frame and to pintle hitch • Pull vehicle forward to tension tow straps • Remove wheel chocks . Back up tow vehicle • Use boat lines to float boat off trailer and to dock • Secure boat to dock • Pull vehicle forward to get trailer out of water • Chock wheels on trailer • Back up vehicle to slack tow straps • Remove tow straps • Remove pintle hitch and deploy regular hitch • Back vehicle to trailer • Hitch vehicle to trailer • Put up port aft jack on trailer • Pull vehicle away from ramp • Retrieve chocks
Retrieval
• Deploy fenders on boat • Let outboard run out of fuel • Move boat to ramp dock • Back trailer to water’s edge • Place chocks behind trailer wheels • Deploy aft port jack on trailer before trailer goes in water • Loosen trailer winch strap 2’ • Unhitch trailer • Pull vehicle forward • Lower trailer jack to set spare tire/wheel on ground • Change vehicle hitch to pintle hitch • Attach tow straps to trailer A-frame and to pintle hitch • Attach line to trailer mast tower • Pull vehicle forward to tension tow straps • Remove wheel chocks . Back up the tow vehicle • Submerge trailer so pads are under water – rear pads 6” under • Step onto boat with line from trailer mast tower • Start motor one more time to finish running out of gas • From bow of boat pull line to move boat onto trailer • Pull boat forward as far as possible • Attach trailer winch strap to bow eye – through middle of roller bracket • Tighten winch strap • Pull vehicle forward to get trailer out of water • Chock wheels on trailer • Back up vehicle to slack tow straps • Remove tow straps • Remove pintle hitch and deploy regular hitch • Back vehicle to trailer • Hitch vehicle to trailer • Put up port aft jack on trailer • Pull vehicle away from ramp • Retrieve chocks • Secure boat with tie-down ratchet straps if needed
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by booyacht</i> <br />Randy, does that tongue wheel flip down for launch or is it fixed at that location? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> It is fixed in that location.
