 leaky window
calden
Initially Posted - 05/16/2011 :  16:30:59  Show Profile
Hey all:
Drip, drip, drip on the inside of aftmost starboard window. I'm looking at the Catalina Direct window resealing kit. Who here has done this? Is it effective? Is it a huge deal to do, or just basically pulling out the old windows and replacing the gaskets? What are other viable options?
Thanks much in advance,
Carlos Alden
S/V Mazama
1983 FK SR
#3682
Response Posted - 05/16/2011 :  18:13:50  Show Profile
http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=20892
Response Posted - 05/16/2011 :  18:36:42  Show Profile
I've done, and so have several others. It is a job, but worth it. The only alternative that I know of is removing the windows, finishing the openings, and applying the stick-on modern windows - a bigger job that changes the aesthetics. There are some caveats if you go with the kit. Search the forum for posts on doing it to get some insight, and post before you start. Send me an email if you want the gory details - it would be a long post.
Looks like the search has been done for you.
Edited by - Dave5041 on 05/16/2011 18:37:38
calden
Response Posted - 05/16/2011 :  21:07:17  Show Profile
Thanks, OJ and Dave. I cannot put out for the really nice upgrades, but it looks like rebedding the existing windows with new seals would work.
Dave, I would love to hear the gory details. I've sent you an email requesting.
calden3 then the AT then that MSN then DOT then com
Thanks much,
Carlos
Edited by - calden on 05/17/2011 22:28:15
bobsta
Response Posted - 05/22/2011 :  09:51:47  Show Profile
Just finished rebedding the port side a week ago. The aluminum frame pops out pretty easy after releasing the screws and frame from the inside. What I learned this year was to go the extra step and take the window out of the frame - frame held together by two small pieces of aluminum. Used silcone to rebed the window into the frame and then 4200 to rebed the frame back onto the boat. Big rain a few days later and no leaks - praise the lord. Work was tedious but well worth the effort - no leaks is heaven..!
