 Cleats on Boom
bobsta
Initially Posted - 05/29/2011 :  03:33:36  Show Profile
I need to put two cleats onto my boom (for back-hauling the clew). The block presently on the boom is riveted on, which seems to be working well. Can I just screw the cleats onto the aluminum boom.
Response Posted - 05/29/2011 :  04:16:00  Show Profile
I added a cleat on the boom for a reefing line. I drilled and then tapped the holes for screws. You will need to use anti-seize, or something like it, to prevent corrosion.
Response Posted - 05/29/2011 :  06:44:29  Show Profile
Do yourself a favor, run the outhaul to the cabin top and make it a multi-purchase system. Mine is 4:1 and even then it takes some oomph. In conditions that warrant heaving on the outhaul you don't want to be standing while fumbling with a line and cleat at the end of the boom.
Edited by - dlucier on 05/29/2011 14:51:45
Response Posted - 05/29/2011 :  07:12:16  Show Profile
<br />Do yourself a favor, run the outhaul to the cabin top and make it a multi-purchase system. Mine is 4:1 and even then it takes some oomph. In conditions that warrant heaving on the outhaul you don't want to be standing while fumbling with a line and cleat at the end of the boom.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Totally agree . . . here are some ideas from the Harken catalog.
http://viewer.zmags.com/publication/b45b96ae#/b45b96ae/20
Edited by - OJ on 05/29/2011 16:44:11
Response Posted - 05/29/2011 :  16:36:29  Show Profile
Things get outhauled or downhauled. You are outhauling the clew.
Response Posted - 05/29/2011 :  18:42:01  Show Profile
Yeah, we cleat the outhaul at the boom-end and need to point up into the wind to take make it safer...running the line into the cockpit would be pretty sweet!
Response Posted - 05/31/2011 :  07:26:32  Show Profile
My cleats slide into the slot on the top of the boom. Cleat has a jam on one side.
