 Loctite acts as anti-seize also?
Initially Posted - 06/12/2011 :  18:16:25  Show Profile
Changing from fixed to sliding gooseneck this year which will require the use of sail track boom stops.
The stop itself is aluminum and the screw is stainless. I can use blue Loctite to keep the screw from coming loose <i>and</i> prevent seizing as well?
Response Posted - 06/13/2011 :  03:38:50  Show Profile  Visit OLarryR's Homepage
I was just doing a search on Loctite Threadlocker (blue) and perception I get is that if you want things not to loosen, go with Loctite Blue. But if you want anti-seize properties , Loctite sells other products.
Response Posted - 06/13/2011 :  04:18:58  Show Profile
I'm thinking I can achieve both - seal the threads to prevent galling and keep the screw from coming loose. I found 3 stops in my hardware collection and the screws were seized.
Contacting Loctite today . . .
Frank Law
Response Posted - 06/13/2011 :  06:41:06  Show Profile
BE carefull-- Some of the loc tight formulas will require a TORCH to loosen!!!
Frank Law
" About Time"
3519 1983
SR SWK
Response Posted - 06/13/2011 :  08:11:45  Show Profile
Loctite came out with a new product about a year ago - #243.
It has the same strength as the blue 242
Will tolerate <i>some</i> oil that may be present on threads
Acts as a lubricant to aid in assembly
Can be disassembled with normal hand tools - no heat required
Protects dissimilar metals from galling or seizing
http://tds.loctite.com/tds5/docs/243%20NEW-EN.PDF
Edited by - OJ on 06/13/2011 08:35:20
Response Posted - 06/13/2011 :  08:28:36  Show Profile
I've got one of these --&gt;&gt; http://www.catalinadirect.com/index.cfm?fuseaction=product.display&product_ID=167&ParentCat=122 and just removed my boom for the first time in a couple of years. Came loose with no problem and I sail in salt water exclusively.
Response Posted - 06/13/2011 :  08:34:41  Show Profile
I went with this one:
http://www.catalinadirect.com/index.cfm?fuseaction=product.display&product_ID=154
