 Winter cover ideas
Initially Posted - 10/04/2011 :  19:28:31  Show Profile
With all the time and effort we put into finishing the teak there's no way I'm leaving it uncovered in the off-season anymore.
We're considering a custom cover of some sorts . . . over the mast but bypassing the lifelines going straight to the gunwales - incorporating a short slot for the stanchions.
Thought I saw a picture on this forum where someone ran a horizontal rod through the u-shaped brace at the base of the stanchions. I think it provided additional points to tie-off the cover. Maybe that person will see this post and attach the pix here.
On the prior boat we used to bring the covers down to the waterline - but it chafed against the gel coat dulling the finish.
Here's something similar to what I have in mind.
http://www.pbase.com/mainecruising/image/93029646
http://www.pbase.com/mainecruising/image/94317599
1989 C25 TR/WK, #5822
1973 McVay Minuet 19
1975 Jester 12
1981 C25 SR/SK, #2428
1981 C22 SR/SK,
Tanzer 16
Sunfish
Edited by - OJ on 10/04/2011 19:29:39
Tomas Kruska
Czech Republic
Response Posted - 10/05/2011 :  01:16:05  Show Profile  Visit Tomas Kruska's Homepage
For many years I use this kind of cover on my boats:
Make a proper and solid mast support
Then I run the line from the lifeline over the mast to the other lifeline and back, from aft to stern. It will help the cover from making pools of water.
Then I put on this heavy cover
It's made from the material used for truck trailers and as I have it all in one piece I need my brother's help to lay it down over the boat.
I would just suggest to have it split ;-)
Also don't forget to leave the hatches and doors semi-open to prevent dump and mould.
Response Posted - 10/05/2011 :  04:20:46  Show Profile  Visit OLarryR's Homepage
When I had an ODay 23 on Long Island, I got tired of using pieces of wood that I kind of put together on the fly with a different config each time, then throwing my nylon reinforced covers over it. The config you show in your link looks very good and so that is a superior wood configuration compared to what I used to do. What I wound up doing and worked very well - I saw an advertisement in one of the sailing magazines for tube couplings. You buy the tube couplings that came in straights, ells, etc and then purchase electrical conduit tubing. This went up very easy. But I do not know if they sell those couplings any more. I have not seen them any longer being advertised but I have not really been looking for them.
These days, I keep my boat in the water all year-round and I have a cusotm cover that the PO had made for him by a local sailmaker. It covers 85-90% of the topsides except for the bow area. One photo below and more on my website.
Edited by - OLarryR on 10/05/2011 04:22:27
Response Posted - 10/05/2011 :  07:26:18  Show Profile
OJ, I can't see how assembling such an intricate structure and disassembling it in the spring is less work than maintaining your teak. I use something similar to Tomas', draping a large tarp over the mast. Alternatively, should you want to leave the mast up, use the boom as the tent ridge pole and linnes from the mast to the pulpit as a ridge pole forward of the mast.
Renzo
Response Posted - 10/05/2011 :  07:59:27  Show Profile
This is the latest version of a cover system that I have been using for the past 12 years. It uses PVC pipe & 1/2" sprinkler tubing with some 2x4 supports. Looks complicated be after the first year it's easy to put up because you only have to partially disasemble it. added advantage is that the cover is high enough to work under. Tarp is a good quality poly tarp and lasts for 3 or 4 years in Michigan winters, with care and minor duct tape repairs.
Response Posted - 10/05/2011 :  08:08:55  Show Profile  Visit aeckhart's Homepage
I don't have any photos's but, I tie 1x2 boards to the mast and stanchons, and brace these with 1x1 strips horizontally. I then cover the structure with over-lapping 4x8 heavy duty tarps. I use bungy cords to secure the tarp edges to the trailer and cover the bungees with foam pipe insulation to keep them from vibrating in the wind and marring the finish.
We generally get around 180 to 250 inches of snow in the UP of Michigan and plenty of wind off of Lake Superior. This system has worked well for me over the past 23 years..
JimGo
Response Posted - 10/05/2011 :  08:32:29  Show Profile
Renzo, your system is pretty neat! Is [url="http://www.homedepot.com/h_d1/N-5yc1v/R-100030452/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053"] this similar to the tube[/url] that you used? Do you have any idea how many feet of tube you used (ballpark)?
Response Posted - 10/05/2011 :  10:31:29  Show Profile
I elevated my mast to create a peak and working space, took off the spreader and tied my lifeline back rests to the mast, I then used a 20 X 30 tarp tied to the trailer to keep it off the hull.
and then park it in my back yard. I love Kansas.
JimGo
Response Posted - 10/05/2011 :  10:50:23  Show Profile
Frank, did you keep the pop-top open? I guess security isn't as big a deal when you have the boat in your own yard, and I bet it really helped the boat "breathe".
tbosch
Response Posted - 10/05/2011 :  11:10:31  Show Profile
I had good luck building a pvc skeleton that I cover with a tarp. I labelled all of the pieces and it takes me about an hour to re-assemble and cover each fall.
Response Posted - 10/05/2011 :  12:11:51  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by JimGo</i>
<br />Frank, did you keep the pop-top open? I guess security isn't as big a deal when you have the boat in your own yard, and I bet it really helped the boat "breathe".
No but it was nice to be able to have it up while working on the boat over the winter.
JimGo
Response Posted - 10/05/2011 :  12:20:16  Show Profile
Todd, is that 3/4" or 1/2" pipe, and what "guage/pressure"?
tbosch
Response Posted - 10/05/2011 :  12:58:34  Show Profile
<br />Todd, is that 3/4" or 1/2" pipe, and what "guage/pressure"?
I used 3/4", schedule 40 I think (the white stuff).
I included more detail and parts info in this thread:
http://catalina-capri-25s.org/forum/topic.asp?ARCHIVE=true& TOPIC_ID=18727
JimGo
Response Posted - 10/05/2011 :  13:31:26  Show Profile
Thanks Todd! That's pretty impressive. I might have to give that a try.
Renzo
Response Posted - 10/06/2011 :  07:48:15  Show Profile
<br />Renzo, your system is pretty neat! Is [url="http://www.homedepot.com/h_d1/N-5yc1v/R-100030452/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053"] this similar to the tube[/url] that you used? Do you have any idea how many feet of tube you used (ballpark)?
Yep, that's the stuff. I think I used a roll and a half of it. Definately no more than two rolls.
Response Posted - 10/06/2011 :  09:19:06  Show Profile  Visit Prospector's Homepage
I have to second the comment above about getting the system set up such that the pop-top can be opened. As Frank said, it is nice to be able to stand up while you work, but from a safety perspective, you also want to crack that open if you are doing any interior work involving solvents, paint, fibreglass, fumes, etc. A fan placed appropriately, or a suitably windy day can get the boat well ventilated down the tunnel your tarp forms, but if the pop-top is closed, the airflow is greatly diminished.
Response Posted - 10/06/2011 :  09:21:30  Show Profile  Visit Prospector's Homepage
Thomas - being that this will be our first year with the new trailer, I am quite interested in the way you blocked your trailer up and removed the wheels. I assume that this is to keep the rubber out of the sun. I like the idea, but wonder if anyone else is doing this and if there are any reasons to - or not to go to the extra effort.
Response Posted - 10/06/2011 :  09:25:56  Show Profile  Visit Prospector's Homepage
One last thought, when looking at teh photos above, bear in mind that conditions may vary widely between what these preparations are in response to. The winter cover we use has to handle repeated freze thaw cycles and a fair amount of snow, but since we store our boat at home, the system is not as robust as some of these - I just go out once a month and knock the snow off, or drain the tarp if water starts pooling.
Some folks only have to keep leafs and rain off with an occasional skiff of snow. Some are looking at feet of snow with few thaws. Some are looking at wicked winds that could strip a tarp in a moments notice. Your setup has to match local conditions. Check the location in the signature of the person whose setup you like and then decide whether what you want to emulate is for conditions you will face.
Tomas Kruska
Czech Republic
Response Posted - 10/06/2011 :  10:39:33  Show Profile  Visit Tomas Kruska's Homepage
<br />Thomas - being that this will be our first year with the new trailer, I am quite interested in the way you blocked your trailer up and removed the wheels. I assume that this is to keep the rubber out of the sun. I like the idea, but wonder if anyone else is doing this and if there are any reasons to - or not to go to the extra effort.
I removed the wheels because I was replacing for better tires, higher load - 670kg each.
This trailer is custom made without brakes. I need to move it just a few meters in our marina.
If you want to protect the tires from the UV, put some canvas/tarp on them.
Over the winter I have the wheels on but the trailer is secured on that concrete stands to lift it a bit and save the axle suspension.
This concrete stands is an excelent idea of my brother.
Easy to build - just fill the ordinary bucket and cheap. The advantage of it is the wide surface area on which it stands on the ground. There is just grass so normal jack stands could dig in the soil.
Edited by - Tomas Kruska on 10/06/2011 10:43:14
Response Posted - 10/06/2011 :  12:52:30  Show Profile
It's got to be expensive, but one of the best winter storage ideas I've ever read about, around 5 years ago shortly after we bought our boat, was inside an airplane hangar. There was a georgous C-25 that came up for sale in Colorado, an 87 or 89 boat, pristine condition, E-Z Loader trailer, that the guy winter-stored in an enclosed hangar (perhaps he owned a plane too). Boat was on the market for only 2 weeks. Imagine, 4 months/yr in water, 8 months in covered storage.
zeil
Response Posted - 10/06/2011 :  14:00:06  Show Profile
Our boat is covered during the winter under a 20x 30 ft tarp draped over the mast with 1/2" foam at pressure points and bungees to the frame. Tarp lasted 6 seasons before disintegrating. Notice that the stern and bow are propped open to allow for ventilation. Tires are protected with old tarps. Trailer frame is canter-levered up with no load at all on the tires and supported by standard concrete building blocks at 4 corners.
Response Posted - 10/07/2011 :  09:46:10  Show Profile
<br />It's got to be expensive, but one of the best winter storage ideas I've ever read about, around 5 years ago shortly after we bought our boat, was inside an airplane hangar. There was a georgous C-25 that came up for sale in Colorado, an 87 or 89 boat, pristine condition, E-Z Loader trailer, that the guy winter-stored in an enclosed hangar (perhaps he owned a plane too). Boat was on the market for only 2 weeks. Imagine, 4 months/yr in water, 8 months in covered storage.
Years ago I used to store my boats inside and the bird droppings were a real issue, and I could not work on them easily. I would love my own pole barn over my back yard pad.
Response Posted - 10/07/2011 :  10:08:36  Show Profile
<br />. . . the bird droppings were a real issue . . .
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">We had a raccoon make a nest in our cockpit
Response Posted - 01/04/2012 :  17:01:31  Show Profile
Thanks for all of the pix and ideas.
Finally sent template off to canvas maker.
FWIW, trying to minimize the amount of hardware I have to remove and store when the cover comes off each spring. Looking to use a hybrid approach between Frank's (using the mast as a center support)) and the picture in the following link (but using <u>way</u> less lumber.)
http://www.pbase.com/mainecruising/image/140329778
At the rate this project is moving I will have the boat just about covered in time for spring launch.
Edited by - OJ on 01/04/2012 17:05:15
Response Posted - 01/05/2012 :  15:33:43  Show Profile
RE: the airplane hangar, from the pics I saw, it was a completely enclosed one, maybe even heated, so I'd guess bird droppings were not an issue.
Response Posted - 01/05/2012 :  20:34:56  Show Profile
I remember that boat. It was definitely the closest to a new boat that I've ever seen.
