 E-10 Again
Initially Posted - 11/16/2011 :  12:41:20  Show Profile
The current issue of BoatUS magazine has a great myth debunking article on E-10. Read it at your own risk if you blame E-10 for your woes or insist on E-0.
edit: BP, Chevron and Mercury Marine all had input. It could, of course, be a giant corporate conspiracy to ruin our engines so we buy new ones every few years.
Dave B. aboard Pearl
1982 TR/SK/Trad. #3399
Lake Erie/Florida Panhandle
Edited by - Dave5041 on 11/16/2011 12:45:05
Response Posted - 11/16/2011 :  15:44:03  Show Profile
http://www.boatus.com/magazine/2011/december/ethanol.asp
With all due respect, I detected some contradictory statements... like, you don't need a water separator because "ethanol doesn't grab water out of the air". Then they warn against water buildup due to condensation in the tank, and suggest a filter for the junk that ethanol dissolves and "cleans" out of the tank. A Racor separator, for example, does both--it lets water settle out and filters the fuel. Plus, at least one article I've read by reputable sources said that E-10 does indeed capture water vapor (humidity) at the surface, and can suspend condensation from the tank walls until the temperature drops to the point that the ethanol has less capacity for holding water, at which point the water phase-separates and ends up in the bottom of the tank where the pick-up is.
I'll stick with my Racor. But my tank is 110 gallons, and stays full over the winter. Empty 6-gallon tanks are less of a problem off-season.
Edited by - Stinkpotter on 11/16/2011 15:57:09
Response Posted - 11/16/2011 :  16:06:44  Show Profile
Interesting how ethanol is not used in aviation fuel.
Maybe I can buy gas at the county airport next spring . . .
Response Posted - 11/16/2011 :  20:36:05  Show Profile
<br />Interesting how ethanol is not used in aviation fuel. Maybe I can buy gas at the county airport next spring . . .<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">...for probably around $6+ per gallon now--probably higher then. (But how many gallons do you need?)
Response Posted - 11/16/2011 :  21:00:15  Show Profile
Water and Alcohol are miscible. Water and ethanol, for example, are miscible since they mix in all proportions. So much so that the whole of the solution's volume is less than the sum of the two separate volumes. If water is available to the ethanol its hydrophilic characteristic will be delighted to assist. I have never worried about a water filter but now that I have a new motor it seems a good time to go with one. What model interfaces with an outboard?
Edited by - pastmember on 11/16/2011 21:01:11
Response Posted - 11/16/2011 :  21:14:04  Show Profile
ETOH is not truely hygroscopic, but it will absorb condensed water and the water/alcohol mix is soluble in gasoline. Yes, they do recommend a filter for the gunk that can be freed up until a tank is cleaned out by the alcohol, but it isn't for water nor is it contradictory. Water doesn't settle out of E-10 until it gets high enough for phase separation, normal amounts are in solution and pass through the engine with no problems as opposed 10 E-0 that will collect water in the bottom of the tank. A Racor is a fine product if you want to use one, but they are saying that just taking reasonable care of you fuel will work fine. Lower atmospheric pressure, as in an airplane, could result in differing evaporation rates of gas and alcohol and drop you octane rating. Probably not a good thing at 10,000 feet. Throw money at E-0 if you want, but Mercury Marine said "E-10 may be a better marine fuel".
Response Posted - 11/17/2011 :  06:52:42  Show Profile
[url="http://www.mercurymarine.com/media/mercury/documents/2011_Fuel_Care_Webinar-2011-08-25.pdf"]The Myths of Ethanol and Fuel Care with Mercury Marine[/url]
Response Posted - 11/17/2011 :  08:38:22  Show Profile
<br /><blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by OJ</i>
I've seen 100LL at $7.50 a gallon.....
Response Posted - 11/17/2011 :  11:33:27  Show Profile  Visit OLarryR's Homepage
Don,
Thanks for Mercury brief !
Response Posted - 11/17/2011 :  16:37:12  Show Profile
<br />What model interfaces with an outboard?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">http://www.catalina-capri-25s.org/forum/topic.asp?TOPIC_ID=21899&SearchTerms=racor
Response Posted - 11/17/2011 :  16:40:26  Show Profile
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Indeed, we're on an inland lake and probably used only four of the 6 gallons we started the season with.
Response Posted - 11/18/2011 :  06:14:58  Show Profile
Do you think West Marine could be a shill for big business?
Hmmm... Gee Whizzz Dorothy...
Response Posted - 11/18/2011 :  08:35:10  Show Profile
<br />Do you think West Marine could be a shill for big business?<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">No different from CVS...
rrick
Response Posted - 11/18/2011 :  17:49:36  Show Profile
Did they recently take the lead out of Aviation Gas? I was going to buy some 110 octane for a hot cam motorcycle in 2005 but walked away when I learned I'd be burning tetraethyl lead and purchased race gas instead. Today, a local gas station sells E-0 for about 0.50-1.00 dollars more (big warnings on the pump re:the price), and it powers all my lawn equipment, the outboard and is the source for my winter top-offs. The 2007 jet ski manual says drain the fuel tank in winter. In pre-ethanol days (as I'm recreating), the idea was to fill the space with alkane fuel so condensation would be minimal. The quote from the Mercury Marine saying E-10 is "an acceptable fuel for everyday use" is acceptable by me; I just want it all burned out in time for storage (pretty much exempts jugs of lawn gas sitting around for months, winter storage fill-ups, and the 5 gallons the sailboat will use over 3 months).
Response Posted - 11/19/2011 :  09:43:08  Show Profile
It's funny, but I have been topping off the tanks in my lawn tractor, other maintenance equipment, and Miata without a problem for many years in the least hospitable conditions for fuel storage. Southern Ohio winters bounce from sub-zero to thaws regularly, so I do add a shot of stabilizer for winter storage.
