 Off-the-wall idea
JimGo
Initially Posted - 02/01/2012 :  20:42:18  Show Profile
I've commented before that visibility (or the lack thereof) above/around my C25 was really surprising to me. I keep reading of people having problems seeing around/under their jib/genoa/spin. I wonder if something like this would work, mounted either on the bow or even atop the mast:
http://www.harborfreight.com/weatherproof-security-camera-with-night-vision-47546.html?ccdenc=eyJjb2RlIjoiNDA0OTQ2MjgiLCJza3UiOiI0NzU0NiIsImlzIjoiMjcuOTkiLCJwcm9kdWN0X2lk%0D%0AIjoiMTQ5NSJ9%0D%0A&utm_medium=email&utm_campaign=0512b&utm_source=1004
- Jim
Formerly of 1984 C25 named Dragon Wing
NOTE: In my case, PLEASE don't confuse stars/number of posts with actual knowledge. On any topic.
Response Posted - 02/01/2012 :  21:07:12  Show Profile
Doubt it.
Response Posted - 02/01/2012 :  21:25:26  Show Profile
I made a jib pendant. Moved the tack to the top of the pulpit. I can see under my jib just fine.
Response Posted - 02/01/2012 :  21:28:08  Show Profile
Pointed where? And where does the TV sit?
Seriously, there are ways to raise the tack and/or clew of your headsail...
Edited by - Stinkpotter on 02/01/2012 21:29:27
Response Posted - 02/02/2012 :  06:47:48  Show Profile  Visit DaveR's Homepage
Might be fun to mount something like that on the bow for someone in the cabin to watch but I think would be useless as a visual aid. I also use a jib pendant to raise my headsail about a foot but as you get used to your boat I think you learn to deal with the lack of visibility. Very easy to point the bow starboard or port just for a second to reveal your blind spot.
Response Posted - 02/02/2012 :  06:50:46  Show Profile
Jim,
I like the way you think... RV's have back up cameras, why not a bow cam? I think the Bendy Toy people are following me, so don't be surprised if the next Bendy 50' Sense has a cam system. Most modern plotters will accomodate a cam. Most big boy boats use it to monitor the engine and fuel filters... But I see a future wherein Thermal/infared visual displays become common practice.
sten
TCurran
Response Posted - 02/02/2012 :  07:17:03  Show Profile
And here I thought that was the bow-fluff's job
Edited by - TCurran on 02/02/2012 07:17:25
Response Posted - 02/02/2012 :  07:40:38  Show Profile  Visit DaveR's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> why not a bow cam? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
It'd probably have to be on the spreader to keep out of water's way (oh no not more electronics up the mast) and have huge resolution to be effective but could be useful on a larger boat.
Response Posted - 02/02/2012 :  10:19:10  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by DaveR</i>
<br />It'd probably have to be on the spreader...<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">...behind the genny??
Ryan L
Response Posted - 02/02/2012 :  10:33:38  Show Profile  Visit Ryan L's Homepage
There are many reasons why that would be a less than ideal solution... Without getting into it my 2c is jib pennant (as suggested) and/or learn to use a tiller extension so you can sit more outboard. Depending on how your jib is cut the pennant can be a bit more involved than simply running a short piece of line but almost certainly you can get at least some extension without too much trouble.
Another idea might be to install a periscope in your mast? Hmmmm....
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by JimGo</i>
<br />I've commented before that visibility (or the lack thereof) above/around my C25 was really surprising to me. I keep reading of people having problems seeing around/under their jib/genoa/spin. I wonder if something like this would work, mounted either on the bow or even atop the mast:
Response Posted - 02/02/2012 :  10:39:38  Show Profile  Visit DaveR's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">...behind the genny??<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Up at spreader level there's a lot less genny but still you're right.
