 Tiller to rudder attachment
Initially Posted - 07/11/2012 :  16:40:32  Show Profile  Visit delliottg's Homepage
I was just reading through the C-25 cracked rudder thread, and noticed that szymek attaches his tiller to his rudder with a pin, not a bolt. My boat came with a 3/8" bolt and thumb nut, and I've always assumed that was how it was supposed to be. Actually never even thought about it, until a couple of minutes ago.
How do you guys have your tiller attached to your rudder? Bolted, or pinned?
David
C-250 Mainsheet Editor
Sirius Lepak
Edited by - delliottg on 07/11/2012 18:30:00
Response Posted - 07/11/2012 :  19:09:48  Show Profile
Bolted.
szymek
Response Posted - 07/11/2012 :  20:24:42  Show Profile
Good question.. I'll follow along. I looked at replacement parts on CD and they have a bolt with wing nut.
So i guess one of the previous owners must have changed it.
Response Posted - 07/12/2012 :  10:34:49  Show Profile
Mine is attached with a bolt and a wingnut. This allows you to adjust the tension required to raise and lower the tiller. I thought that was the standard setup. Maybe not?
Response Posted - 07/12/2012 :  11:48:13  Show Profile  Visit delliottg's Homepage
<br />Mine is attached with a bolt and a wingnut. This allows you to adjust the tension required to raise and lower the tiller. I thought that was the standard setup. Maybe not?
That's exactly why I asked the question. It seems like the bolt & wingnut is winning so far. I keep mine fairly tight, but I've got my "emergency" tiller on the boat right now, and it has the SS straps to attach with instead of the SS cap that the regular rudder attaches with. I kind of like the "emergency" tiller, it's shorter, so it's less in the way, but I prefer the regular tiller when I'm maneuvering in the fairway, easier to stand up without crouching to use. Tightening the nut on the regular tiller doesn't really accomplish much, it can't compress the SS cap very much to increase tension. Also the emergency tiller doesn't have an attachment for my tiller extender, so unless I've got my autopilot attached, letting go of the tiller results in random action from the rudder.
Edited by - delliottg on 07/12/2012 11:50:01
Response Posted - 07/12/2012 :  12:47:45  Show Profile
Our tiller is a wheel. Our emergency backup tiller has a bolt and wingnut.
edguide1
Response Posted - 07/13/2012 :  14:47:30  Show Profile
Pinned
