 2-3 Knots with Keel Up
sethp001
Mainsheet C-25 Tech Editor
Initially Posted - 07/26/2012 :  11:46:08  Show Profile
A couple of weekends ago, we were on a run in light winds, and I tried lifting the keel to see if there was any difference. I was surprised when we got an extra 2-3 knots.
Unfortunately, I haven't install the keel spacers yet and the keel banged back and forth so loudly that I put it back down.
Do any of you regularly raise your swing keels on runs and find this type of speed improvement?
Seth
"Nomad" 1980 Prindle 16
Chris Z
Response Posted - 07/26/2012 :  12:10:36  Show Profile  Visit Chris Z's Homepage
I am not sure I would want to raise my keel unless I ran into shallow water or launching. The issue is that unplanned things happen when sailing and if you were forced to turn up wind quickly you would be in quite a spot without the keel down.
I don't think they ever intended for the swing keel to be up when sailing.
Response Posted - 07/26/2012 :  13:18:26  Show Profile
The only way raising the keel could have made a difference of 2-3 kts in boatspeed would be if some weeds or a crab pot had been caught on the keel, and they fell off when you raised it. I suspect you caught a wind puff at the same time you raised the keel. When sailing downwind, you might not have felt the presence of the puff.
We have discussed this before, and, while some think raising the keel increases speed, even the "believers" only claim a fraction of a kt increase.
IMO, nobody has ever made out a very good case for why it makes a difference. Raising the keel on a C25 doesn't reduce wetted surface. The keel doesn't retract into a keel well, or lift out of the water like a daggerboard. It just rotates up against the bottom of the boat, so that you are dragging the same amount of surface area through the water as when it is down. Instead of presenting the foil-shaped edge of the keel to the water flow, you are presenting the blunt end of the keel to the water flow. Raising the keel moves the center of gravity aft somewhat, but I don't see how sailing stern-down makes the boat faster. You'll get both sides of the argument here, but you're not likely to get a definitive answer. There is disagreement here, with some of the best sailors on both sides of the issue.
Response Posted - 07/26/2012 :  14:07:20  Show Profile
What Steve said. Another problem with the goal to increase speed down wind by raising the keel is down wind is when you get quartering waves and raising the keel would exacerbate the "roll" that can accompany a quartering wave. You can help yourself a lot more by fairing the keel and leaving it down.
Response Posted - 07/26/2012 :  15:24:24  Show Profile
The wetted surface may not be less, but the area of the forward-facing surface of the keel, which creates the most drag, will be some fraction of that of the lowered keel--possibly decreased further by the release of a big blob of seaweed.
In any case, I suspect the boat was designed to have the keel down whenever the sails are up, just as the C-250 WB must have the ballast tank full when the sails are up. Doing otherwise creates the possibility of a situation like that of the Silverton on the 4th of July. That skipper can attest to the difficulty of explaining things after the tragedy. ("Your Honor, I was just seeing if I could get another knot out of her...")
Edited by - Stinkpotter on 07/26/2012 15:26:34
PCP777
Response Posted - 07/26/2012 :  15:48:09  Show Profile
<br />The only way raising the keel could have made a difference of 2-3 kts in boatspeed would be if some weeds or a crab pot had been caught on the keel, and they fell off when you raised it. I suspect you caught a wind puff at the same time you raised the keel. When sailing downwind, you might not have felt the presence of the puff.
This was interesting. I crewed on a S2 7.9 and we always hauled up the dagger board down wind when flying the spin but alas, as you've pointed out, it is a dagger board. (And a true PIA to winch up!) Small boats with a centerboard complete with centerboard trunk so that the centerboard goes all the way up into the hull also can take advantage of this.
What you have said about the swing keel makes sense.
I really don't know how much more speed we got out of lifting the dagger board on the S2 either. Not 2 to 3 knots for sure.
Response Posted - 07/26/2012 :  19:40:24  Show Profile
I gave this some thought but never got around to testing it since I think it adds significant risk as noted. Most of what I balanced has already been mentioned. Positive effects: slight reduction of keel surface in the water stream since some is shrouded in the slot, major reduction of frontal area, shifting the CG aft would help get on a plane (joke, please) Negative effect: turbulent flow caused by the slot runs the full length of the keel and causes a major increase in surface drag. I could see it adding a very small advantage in light winds and speeds below the threshold of turbulence, but who knows. Potentially a lot to lose and very little to gain.
Response Posted - 07/27/2012 :  08:32:03  Show Profile
On our old C22 we raised the keel about 2/3rds of the way and the speed actually increased by 1/2 a knot. I can't explain it, just know it worked.
Response Posted - 07/27/2012 :  09:42:00  Show Profile
<br />On our old C22 we raised the keel about 2/3rds of the way and the speed actually increased by 1/2 a knot. I can't explain it, just know it worked.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Downwind, up, or both? Maybe she liked the weight shifted aft. Maybe it's like sweeping an airplane's wings back. (The speed is lower, but the fluid is thicker.)
Response Posted - 07/30/2012 :  16:42:38  Show Profile
FWIW...I'm w/ Chris 110%...
Response Posted - 07/30/2012 :  20:54:48  Show Profile
Maybe the keel closing up some of the keel slot reduces some of the turbulence and drag created by the opening?
Response Posted - 07/31/2012 :  08:52:10  Show Profile
Dave - we only raised it going downwind. I'd hate to go to weather with it down!
Response Posted - 08/01/2012 :  08:26:24  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">I'd hate to go to weather with it <b>down</b>!<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Maybe that's why you mixed up the "Side UP" on that boat... ? (Inside joke.)
Edited by - Stinkpotter on 08/01/2012 08:29:41
Response Posted - 08/01/2012 :  08:58:23  Show Profile
That was an "oops"...
