 Resealing keel bolts/getting rid of moisture
treeder65
Initially Posted - 07/31/2012 :  08:52:43  Show Profile  Visit treeder65's Homepage
I have had my boat on the hard for a while and have been repairing the "Catalina Smile" on the fin keel and basically getting it ready for a good bottom job. I knew that some rain water was getting into the bilge but did not realize that it was getting under the keel bolts and some other holes in the bilge. I used a hole saw to cut 2" holes in the fiberglass between the keel bolts to expose the wood core. There is a puddle there on the wood. The bottom is already sealed with Interluxe 3000 and I am waiting to apply the VC 17; in the meantime, I want to dry out the core and reseal the bilge and keep bolts. I tarped the boat so no more water; I have a dehumidifier in the cabin to get some of the moisture out. Is this the best method? I searched for a past thread but no luck. Any advice or leads to previous posts regarding moisture removal and the process of resealing keep bolts would be appreciated. Although I am selling her, I want to do it right. My thought was to dry it out, coat with West System Epoxy followed by Interluxe 3000, then apply butyl tape around the bolts before adding SStl washer, lock washer and the double nuts.
Thanks.
Tom
1986 C25 SR/FK #5299
Hunterdon County, NJ
Edited by - treeder65 on 07/31/2012 08:57:40
Response Posted - 07/31/2012 :  09:09:02  Show Profile
This C27 factory instruction for repairing the wood in the keel stub core may provide guidance.
[url="http://www.blumhorst.com/catalina27/images/keel_factory_drawings/keel_stub_wood_procedure_from_catalina.gif"]C27 Drawing[/url]
You can probably contact Catalina for guidance as well.
treeder65
Response Posted - 08/01/2012 :  05:50:08  Show Profile  Visit treeder65's Homepage
Thanks Don. That's exactly what I was looking for.
Response Posted - 08/01/2012 :  08:15:18  Show Profile
Too bad Catalina didn't take that approach when they built the boat.
Response Posted - 08/01/2012 :  08:23:36  Show Profile
Who knew we'd be sailing them 30+ years later? (...and talking about these things in front of everyone on the World Wide Web! )
