I read Dragon Tails explaination of the skeg mounted DS51 transducer but could not see the picture very well. The PO has installed the depth gage but it looked like he gave up on the transducer because the transome is so far out of the water (which is my reaction, as well). I e-mailed Standard Marine about the possibility of converting the DSTS51 to an 'In Hull' transducer, mounted in a water tight container, epoxied to the floor of the hull. No answer from them, just yet. I had seen this idea executed somewhere, but can't find it now that I need it. What suggestions do you have for me? Thank you...NuNees C25 SKSR 4953.
The idea of mounting the transom mounted transducer in a mineral oil or water bath in a container inside the hull was discussed in a recent topic and it sounds reasonable. Towards the end of the discussionhttp://www.catalina25-250.org/forum/topic.asp?TOPIC_ID=2457 some posted their ideas on how to mount this type of transducer.
Another option would be to buy the Standard Horizon DST55 "In-Hull Puck" transducer(SailNet $49.95 or West Marine $69.99, catalog page 154), and simply glue it to the hull.
Keep in mind that SailNet doesn't charge sales tax(unless in SC) and advertises free shipping.
The transducer for "Quiet Time"'s depth sounder is a transom mount, powerboat type, that came with the Garmin 125 GPS/Sounder. I have it mounted on a piece of aluminum plate 2" wide, 1/4" think, 12" long, that extends down from the back of the skeg. The plate is attached with a couple of screws to the skeg above the waterline, and the transducer cable is routed to a small hole in the transom next to the outboard motor. This arrangement probably induces some slight amount of drag - a dedicated racer would never do it this way, I suppose - but it did allow me to use the transducer that came with the unit, without drilling into the hull below the water line, something I hate to do. One other downside to hanging the transducer this way is that anything floating at the surface like kelp is likely to get caught in it, and the transducer is vulnerable to getting whacked off if I should run over a large enough piece of driftwood. On my next boat, which will be an '88-'90 WK/SR, I will probably use a regular thru-hull transducer in the floor of the head compartment.
Larry Charlot Catalina 25 #1205 "Quiet Time" Sacramento, CA
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote> I read Dragon Tails explaination of the skeg mounted DS51 transducer but could not see the picture very well. The PO has installed the depth gage but it looked like he gave up on the transducer because the transome is so far out of the water (which is my reaction, as well). I e-mailed Standard Marine about the possibility of converting the DSTS51 to an 'In Hull' transducer, mounted in a water tight container, epoxied to the floor of the hull. No answer from them, just yet. I had seen this idea executed somewhere, but can't find it now that I need it. What suggestions do you have for me? Thank you...NuNees C25 SKSR 4953.
Thank you for the tips. The discussion at 2457 had the answer I was looking for. I'll test it as suggested and then have a go at it. If it doesn't work out I'll do a SailNet...Thanks again.
