 Sailboats don't use throughhull intake strainers?
rrick
Initially Posted - 09/26/2012 :  21:18:34  Show Profile
I took this home today for $5 It would be nice to bolt over the through hull I want to use as for a washdown pump.
Molly Brown: 1967 Grand Banks 32-#34. Bronze, mahogany, teak, oak, with 120hp diesel to push all 10 tons. Currently an abuser of the bilge pump. Also... The Tall Rig Spirit: 1978, #973, Cast Fe Fin Keel on a Trailer
Response Posted - 09/26/2012 :  21:43:13  Show Profile
Sailboat definitely use them--for inputs to the raw-water side of their inboard engine cooling systems, where a blockage could be a huge problem. There's no reason for you not to use one, but I wouldn't call it critical.
rrick
Response Posted - 09/26/2012 :  21:47:00  Show Profile
I wondered if they took away from the smooth hull experience, maybe even noisy on a particular heel. To minimize, grate is pointed backwards if your only using the water draw at dock, right?
Response Posted - 09/27/2012 :  04:55:59  Show Profile
looks like the cat is interested in a different straining method?
raw water intakes for the engine is a primary use......but yes on sail and stink boats
Response Posted - 09/27/2012 :  05:55:26  Show Profile
Any intake can be clogged by anything that floats against it. Around here, unprotected engine, AC, refrigeration, washdown and other intakes can suck a jellyfish into the system, clogging it. Sometimes jellyfish are so abundant in my marina that, when a system stops working, its the first thing you look for, before you think of replacing a $200. pump. I spent half a day helping a friend remove and rebuild his engine water intake pump, and we found out it was clogged by a jellyfish. If there's a screen over the intake, then whatever is clogging it will usually just drop off if you shut off the intake pump and wait a few minutes. Lesson learned!
rrick
Response Posted - 09/27/2012 :  10:36:29  Show Profile
That cat has a history of getting in shots. The minute I set something up for ebay etc and grab the camera, he jumps up and wants to know what is more important than him. I call this photo Sail Cat
Edited by - rrick on 09/27/2012 10:37:17
