Is the caulking on fabric or gelcoat ? If on fabric, that's going to be tough to get out. If gelcoat (or other non-porous material) I'd wait for it to dry, then use a scraper to carefully scrape it off. Then use a fine rubbing compound (like 3M one-step) to get any remaining residue..
Assuming your were sealing a piece of deck hardware with a polysulfide caulk, and got a little on the gel coat, you might try using a little acetone to remove the caulk.
You might even try scraping it off, but don't use a metallic tool(razor, screwdriver, paint scraper,...etc), because you may shave off the gelcoat especially if it is on non-skid. Instead, I use a wood shim to get the rubbery caulk off of the gelcoat without harming it. Just use the wood shim(or similar piece of soft wood) as you would a paint scraper and gently scrape the caulk.
This technique works good on polysulfides sealants, but I'm not sure how well a polyurethane caulk can be removed since it is more of an adhesive than a caulk.
Don Lucier, 'North Star' C25 SR/FK Cradled on the hard, 200ft from Lake Erie
This <img src=icon_smile_blackeye.gif border=0 align=middle> is what happened to me the last time the Admiral caught me gaulking <img src=icon_smile_tongue.gif border=0 align=middle>.
hey thanks for the tip.. i worked on it a little and got a considerable amout off by painstakingly scraping with my nails. I think the wood shim should work as well... thanks for the help -marco
I keep a package of inexpensive Home Depot shims on the boat and I use them for a variety of tasks, including caulk removal. They can also be used to stir paint, scrape bird doodoo, mix epoxy, apply fillers,...etc, and they're disposable.
