 deck light prism repair
dasreboot
Initially Posted - 06/12/2013 :  05:19:12  Show Profile  Visit dasreboot's Homepage
cracked the little deck light in the bow by standing on it. Has anyone repaired this in the past?
Todd Lewis
Eowyn 87 TR/WK C25 #5656
ARWEN 84 TR/SK C25 #4031
www.mainsailsailingschool.com
Response Posted - 06/12/2013 :  05:49:02  Show Profile
I tried the CD direct replacement and could not get it to seal correctly. Still leaks. Need to replace it with something else.
I think I might glue it up from the bottom, ( glue on a larger piece of plexi on the under side of the deck. ) and then fill from the top with resin. Then cap with the CD direct part to make it flush.
That should seal it up and make it stronger.
Response Posted - 06/12/2013 :  06:40:04  Show Profile
The [url="http://www.catalinadirect.com/index.cfm?fuseaction=product.display&product_ID=1321&ParentCat=35"]Catalina Direct kit[/url] worked for me (although I didn't use the inside lens they provided). It's meant to be set into a heavy bead of silicone so the sealer fills in around the sides. But if I had to do it again, I'd have a plastic shop cut a thicker piece of Lexan and bevel the top edges slighly to make an even stronger lens.
Edited by - Stinkpotter on 06/12/2013 06:43:54
Response Posted - 06/12/2013 :  07:41:52  Show Profile
I bedded mine in polysulfide... apparently not the right material for this application. I'll try it again with silicone.
Response Posted - 06/12/2013 :  08:05:45  Show Profile
Response Posted - 06/12/2013 :  08:50:31  Show Profile  Visit Prospector's Homepage
I bed mine with boatlife.
I think it was 3 years ago. No trouble since. Maybe I'm the anomoly. I also had the replacement prism made up by a local plastics shop. Using the drawing Redeye posted, with a couple customizations...
I used thicker plastic and had it bevelled at about 5° to eliminate the raised lip others have had issue with.
Blogpost is here, but the pics went AWOL a while back. http://frosthaus.blogspot.ca/2010/07/a-room-with-view.html
Response Posted - 06/12/2013 :  09:17:06  Show Profile
Polysulfide (Boatlife Life Caulk) is "incompatible" with most plastics. I don't really know the consequences of that, but I go with Boatlife Life Seal with plastics--it's a silicone-polyurethane hybrid that's compatible with plastics, is moderately adhesive, but is removable without taking gelcoat with it (like polysulfide).
Response Posted - 06/12/2013 :  10:36:52  Show Profile
I made a new one out of 1/4" thick translucent white acrylic. We used LifeSeal, not LifeCaulk.
I cut it on a small CNC mill and can share the drawing for that if it is helpful. I found that the dimensions in the Catalina drawing were a bit off and had to cut it 1/8" smaller.
Response Posted - 06/12/2013 :  10:38:38  Show Profile
Ah Ha... I went with boatlife caulk and it has been leaking. A real bummer... Next time ( which should be soon ) I'll try boatlife Seal.
Yep... just a tad smaller would have been better for mine also.
Edited by - redeye on 06/12/2013 10:39:34
