 What does this do?
Initially Posted - 06/29/2013 :  05:05:56  Show Profile
The luff on my main sail has an arrangement of line that runs between the slides...why? What do I do w/ it?
It is a bit annoying w/ a reef tucked in...as shown in the photo, the luff is away from the mast...I need to go forward to tighten the line, but that defeats the purpose of shortening sail from the cockpit...
THANKS!
Jerry
Edited by - jerlim on 06/29/2013 05:11:16
Response Posted - 06/29/2013 :  07:08:40  Show Profile
Looks like an attempt to make a mainsail jackline:
Catalina Direct:
http://www.catalinadirect.com/index.cfm?feature=34
Supposed to allow the sail to fall away from the mast/boom for better reefing.
Response Posted - 06/29/2013 :  07:27:07  Show Profile
Funny - with this weird summer weather in LI Sound, I've kept my main reefed on my past several outings. I don't have that kind of arrangement with the lower track slugs but I've never noticed a problem with the luff bunching up. Could this be a solution in search of a problem?
Response Posted - 06/29/2013 :  07:38:43  Show Profile
It looks like Jerry has both a jackline and mast gates. You don't need both, but one or the other is very helpful.
They both solve the same problem, which is letting the mainsail get down tight on the boom even though the opening in the mast track is well above the boom. The jackline does this by letting the sail get away from the bottom few sail slugs when there is no tension in the sail. The slugs sit above the mast track while the sail curls up below. The mast gates do it by allowing the sail slugs to slide past the opening in the mast.
Considering the rough cut of the mast slot on a Catalina mast I think I'd prefer a jackline on a C-25. With a more modern mast that includes a nicely machined mast gate I do prefer the mast gate solution.
Edited by - awetmore on 06/29/2013 07:39:25
Response Posted - 06/29/2013 :  08:17:53  Show Profile
The picture definitely looks like the sail is designed for reefing jacklines, but the slugs are not tied in properly for them. If you have a mast gate you don't need them, but you should definitely improve the way the slugs are tied in to improve sail shape by eliminating the large gap between the mast and your luff.
FWIW, I have a reefing jackline AND a mast gate. The jackline works for a single reef, but not for a double reef, so I added the mast gate for when I double reef.
Response Posted - 06/29/2013 :  13:40:06  Show Profile
Take-five, a mast gate is precisely why you do need them. If you have a mast gate and a sail slug stop in place just above the mast gate, the slug jack line acts as an extension cord for the slug allowing the sail material to pull away from the slug to be folded down closer to the boom when you reef the main
If you do NOT have an open mast gate, then the jack line will not be any benefit.
Edited by - dmpilc on 06/29/2013 13:45:35
Response Posted - 06/29/2013 :  18:32:42  Show Profile
Many thanks to all responders...based on the insights and as we have mast gates, I plan to revert to simple slugs and will advise on any effects - Fair winds - JL
Response Posted - 06/29/2013 :  20:40:53  Show Profile
<br />Take-five, a mast gate is precisely why you do need them. If you have a mast gate and a sail slug stop in place just above the mast gate.
If you have a stop above the slot, then you don't need a mast gate anyway.
I used a sail stop without a mast gate for two years, but when I decided to rig a second reef, I installed a mast gate and took out the stop. There's no need for both a mast gate and a stop.
Response Posted - 06/30/2013 :  04:50:19  Show Profile
Just read the product description on CD:
<font size="4"><font face="Times New Roman">A Jackline eliminates the need to go to the mast during a reef. Reef from the safety of the cockpit. Standard on all Catalina Direct Mains'ls
The bottom luff slides are attached to the sail via the Jackline. When the sail is at full hoist, the Jackline is tight and the sail is held against the mast. When you reef, the jack line goes slack allowing the reef cringle to reach the gooseneck.</font id="Times New Roman"></font id="size4">
There seems to be a contradiction here...the first paragraph references reefing from the 'safety of the cockpit', yet describes that the reef cringle can reach the gooseneck...<i>which needs to be done from the mast...</i>
Response Posted - 06/30/2013 :  05:06:55  Show Profile  Visit britinusa's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jerlim</i>
<br />
The Reef 'Cringle' is the eye in the sail that the reefing downhaul line pulls down at the mast. So if the downhaul is ran back to the cockpit, there is no need to go forwards.
I switched out to the 2 line reefing, so the downhaul is a separate line, but even with single line reefing, the reefing line doubles back to the Reefing Cringle before turning back down to the mast foot.
<center>
<b>Single Line Reefing</b>
Extract from the C250 Owners Manual</center>
Edited by - britinusa on 06/30/2013 05:11:53
